blitZ |
Beer please... ![]() ![]() ![]() ![]() Group: Members Posts: 2,223 Joined: 31-August 05 From: Lawrenceville, GA Member No.: 4,719 Region Association: South East States ![]() |
I upgraded to a 22mm Weltmeister sway bar a few years ago. During some routine maintenance, I noticed it was hard to move. So, I removed it, cleaned and lubed the bushings and now moves freely. Ever since, I get a clunking sound when I hit a bump or hole in the road. I think it is adjusted correctly, there seems to be no load on it sitting flat.
There was a little side to side play and I limited it by adding some washers and felt material to snug up each side. Any ideas as to what is the cause? |
ConeDodger |
Apex killer! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,097 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California ![]() ![]() |
Did you remove your gas tank when you were doing this work? Sometimes when you get the gas tank in deep, it rattles against it.
blitZ |
I took the tank out when I installed the new bar, there is plenty of clearance. That's the first thing that came to mind when I noticed the bar would not move freely, that the tank had settled on it. But that's not the case.
brant |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,010 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains ![]() ![]() ![]() |
Probably you did this...
but when ever installing a bar its nearly impossible to get each side lined up perfectly... (plus these cars have a bit of variation even if you measure) its critical to tweek things to get each side as much inline with the other during install as possible. Plus I ABSOLUTELY install zerks into bar bushings. I did so on my welts and also on my smart racing bars. Once on the old race car (15 years back?) I ripped out a 6inch are of the inner fender where the sway bar bushing was. Thats when I learned that these bushings are a maintanence item and require frequent lube. Once they bind, they tear I'd remove it again... clean.. lube... and install zerks into the bushings. |
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
Hollow 22mm weltmeister bars do flutter when not under stress (like a hard corner etc.)
Two things I did. One, get 22mm pipe clamps so you can center the bar...it will slide side to side. Second, cut a piece of garden hose and slice it all the way down the length. Put that over the bar. It stops the flutter and helps keep it centered also. Rich |
Lo-Fi Version | Time is now: 9th July 2025 - 08:11 AM |
