PCG.571.900.00, water drain hose |
Posts in this area are restricted to the following format. If you have a general question, please post it in the Garage.
1. All new threads MUST be titled with a part number only. (i.e. 901.351.801.17)
2. Thread description should be an english description of the part. (i.e. Brake Dust Shields)
3. Replies to the thread are only restricted by pertinence. Some examples are original finish of the part (painted, cad plated, etc), common failures (cracking at the mount points), repair information or tips, pictures (stock or custom), upgrades, etc.
If you have any questions regarding the rules of this forum, please PM McMark.
A&PGirl |
Mar 20 2010, 05:00 PM
Senior Member Group: Members Posts: 1,019 Joined: 4-January 06 From: Oklahoma Member No.: 5,367 Region Association: None |
PET 813-00 #6, 7, 9.
Qty: 1 each. #6 is 75mm and #9 is 400mm. No length mentioned for #7. PET 803-05 #40 Qty: 2 No length given. Construction: Flexible corrugated non-porous black plastic. ID: .92 inch OD:1.091 inch |
type47 |
Sep 28 2010, 11:12 AM
PET 813-00 #6, 7 and 9
5 E 999.512.165.01 hose clamp 6 75mm 7 8 914.571.153.10 t-piece water drain hose 9 400mm PET 803-05 # 40 water drain hose qty:2 Drain hose for engine lid rain tray NLA http://www.914world.com/bbs2/index.php?sho...;hl=drain++hose |
Phil Plummer |
Feb 10 2012, 03:31 PM
Member Group: Members Posts: 120 Joined: 7-January 12 From: Edmonton Ab Canada Member No.: 13,973 Region Association: Canada |
PET 813-00 #6, 7, 9. Qty: 1 each. #6 is 75mm and #9 is 400mm. No length mentioned for #7. PET 803-05 #40 Qty: 2 No length given. Construction: Flexible corrugated non-porous black plastic. ID: .92 inch OD:1.091 inch Dioes anyone out there know about some guy in world selling new 914 rubber trim & seals? |
gothspeed |
Mar 23 2012, 11:07 AM
Senior Member Group: Members Posts: 1,539 Joined: 3-February 09 From: SoCal Member No.: 10,019 Region Association: None |
This original hose may be NLA. In such case;
I used 5034K18 from mc master carr and the material construction was perfect for this application. Nice interference fit (no hose clamps needed) and it sealed well in the factory grommets. IMO it looks much cleaner than the corrugated stuff. 5034K18 Abrasion-Resistant Blk Neoprene Rubber Tubing 7/8" ID, 1-1/8" OD, 1/8" Wall Thk http://www.mcmaster.com/#catalog/118/140/=gsfrkc |
Lo-Fi Version | Time is now: 4th May 2024 - 06:16 PM |
