car running bad |
car running bad |
GreatPumpkin |
Mar 26 2010, 04:23 PM
Member Group: Members Posts: 122 Joined: 28-October 07 From: Centerville OHIO Member No.: 8,272 Region Association: None |
we did get new plug wires but the piece of the wire that connects to the spark plug wont connect to the second spark plug and looks different from the rest of these pieces.
GreatPumpkin |
Mar 26 2010, 04:26 PM
the 2nd and 3rd plugs are the same and if they grasp the threads on the spark plugs be stripped
jsaum |
Mar 26 2010, 04:39 PM
Senior Member Group: Members Posts: 530 Joined: 12-June 07 From: Everett, WA Member No.: 7,809 Region Association: None |
The plug wire insulators with the spring clips inside will push on and seem like they're stripping the threads but don't. I had a new set just recently where one of the wire spring clips became dislodged when I pulled the wire off. I was able to put it back in place with some needle nose pliers and make it work. How does the wire look different?
Jsaum |
GreatPumpkin |
Mar 26 2010, 04:49 PM
it doesnt go on very far and doesnt click like the thers when you put them on. also when you put this plug insulator on it is very loose no matter how hard i push on it
tod914 |
Mar 26 2010, 05:42 PM
I can't really tell from your picture, but does that spark plug have cap on the end? Not sure what's it called, but when you get new spark plugs, you have to unscrew the cap to show the threads on the portion of the plug where the wires attach. That looks like that cap is on, but hard to tell. Would explain why the wires aren't going on it.
76-914 |
Mar 26 2010, 05:55 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,508 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
I can't really tell from your picture, but does that spark plug have cap on the end? Not sure what's it called, but when you get new spark plugs, you have to unscrew the cap to show the threads on the portion of the plug where the wires attach. That looks like that cap is on, but hard to tell. Would explain why the wires aren't going on it. (IMG:style_emoticons/default/agree.gif) I saw the same thing. Wonder if there is any correlation between this and the missing clip? Hmmm |
GreatPumpkin |
Mar 26 2010, 09:32 PM
ill have to check tomorrow, if this is true how would i unscrew the cap it must ba very small.
tod914 |
Mar 27 2010, 06:37 AM
Remove the plug and unscrew it by hand. I doubt it's on that tight. Don't over tighten the plug when you put it back in. Just make it snug. If you go too much you can strip the threads on the head.
Lo-Fi Version | Time is now: 8th June 2024 - 05:45 AM |
