Help! My 914 1.8 is revving high!, help with mechanical problem |
Brandi |
Mar 26 2010, 11:06 PM
Newbie Group: Members Posts: 6 Joined: 26-March 10 From: Los Angeles Member No.: 11,510 Region Association: Southern California |
Hello all --
I have a 1975 1.8 that seems to have either a stuck throttle cable, or stuck float. here's the issue: When I start the car it promptly shoots to 5500 RPMs -- it's revving high. The gas pedal moves smoothly, and the cable in the engine compartment doesn't seem to be stuck. I've tried adjusting the idle screw, but it doesn't have any affect one way or the other. Can anyone help with this -- what can I do? I'm getting desperate. The weather's good, and I want to drive my baby! Thanks for any advice. |
Kirmizi |
Mar 27 2010, 12:49 AM
Senior Member Group: Members Posts: 836 Joined: 12-February 06 From: Wyoming, US Member No.: 5,568 Region Association: None |
Carburetors? One or two?
I'd start by checking the linkage(s) to see if anything's binding. Then check the butterflies to make sure they're closing properly. Mike |
RJMII |
Mar 27 2010, 03:24 PM
Jim McIntosh Group: Members Posts: 3,125 Joined: 11-September 07 From: Sandy, Utah Member No.: 8,112 Region Association: None |
Mike's got some good advice there. =o) pull the air filter(s) and look at the butterflies. |
PeeGreen 914 |
Mar 27 2010, 03:34 PM
Just when you think you're done...wait, there is more..lol Group: Members Posts: 10,219 Joined: 21-September 06 From: Seattle, WA... actually Everett Member No.: 6,884 Region Association: Pacific Northwest |
Are you sure the throttle cable isn't wrapped around the clutch at the pedal cluster? I have seen the cable drop down and wrap itself around the area where the clutch cable attaches causing something like what you are saying.
TheCabinetmaker |
Mar 27 2010, 03:40 PM
Undo the cable from the linkage. That will eliminate one of the two.
Brandi |
Mar 27 2010, 05:42 PM
Thanks guys --
I pulled the air filter, and everything seems to be moving okay. Although I've had my 914 for 10 years, and I've done a lot of work on it myself, this is a new one for me. When I pulled the AF off, there wasn't any butterfly under it (unlike say, a buick). The accelerator pedal is moving freely -- doesn't stick. What else can I check? |
Brandi |
Mar 27 2010, 05:43 PM
BMXerror |
Mar 27 2010, 05:51 PM
Senior Member Group: Members Posts: 1,705 Joined: 8-April 06 From: Hesperia Ca Member No.: 5,842 |
Help! My 914 1.8 is revving high! SHIFT! Sorry.... Couldn't help myself. (IMG:style_emoticons/default/biggrin.gif) BTW (IMG:style_emoticons/default/welcome.png) Mark D. |
Brandi |
Mar 27 2010, 05:55 PM
Help! My 914 1.8 is revving high! SHIFT! Sorry.... Couldn't help myself. (IMG:style_emoticons/default/biggrin.gif) BTW (IMG:style_emoticons/default/welcome.png) Mark D. Is THAT what that stick thingie is for???? Thanks for the laugh -- I needed that. |
PeeGreen 914 |
Mar 27 2010, 06:06 PM
The gas pedal will still move freely if it is looped at the pedal cluster. Remove the pedal board and look at where the accel and clutch cables connect to the cluster. Should only take five minutes and then you can cross it off you list of possible causes.
Kirmizi |
Mar 27 2010, 06:12 PM
Here's a pic of a single carb butterflies and another where the throttle cable connects. Mike
Tom |
Mar 27 2010, 06:13 PM
Advanced Member Group: Members Posts: 2,139 Joined: 21-August 05 From: Port Orchard, WA 98367 Member No.: 4,626 Region Association: None |
Fuel injection or carbs? You said you took the AF ( singular) off and didn't see a butterfly. Carbs would have two air cleaners. If fuel inj., I think air leaks cause high RPMs.
Tom |
Brandi |
Mar 27 2010, 06:39 PM
Fuel injection or carbs? You said you took the AF ( singular) off and didn't see a butterfly. Carbs would have two air cleaners. If fuel inj., I think air leaks cause high RPMs. Tom Okay, I feel pretty dumb, but... I'm pretty sure I have fuel inj. In my defense, the car was parked for 2 years before going into the shop. Two years is long enough to forget most of what I once knew!! It came out of the shop, ran fine, no problems. It sat for 2 months, and when I fired it up, the gas pedal stuck, then came free and now it's idling high. I'm going to try to pull the pedal board tomorrow and see if that's the problem. |
Rick L |
Mar 27 2010, 07:42 PM
Member Group: Members Posts: 405 Joined: 12-November 05 From: Columbia-ish, MD Member No.: 5,116 Region Association: North East States |
Fuel injection or carbs? You said you took the AF ( singular) off and didn't see a butterfly. Carbs would have two air cleaners. If fuel inj., I think air leaks cause high RPMs. Tom Okay, I feel pretty dumb, but... I'm pretty sure I have fuel inj. In my defense, the car was parked for 2 years before going into the shop. Two years is long enough to forget most of what I once knew!! It came out of the shop, ran fine, no problems. It sat for 2 months, and when I fired it up, the gas pedal stuck, then came free and now it's idling high. I'm going to try to pull the pedal board tomorrow and see if that's the problem. The L-Jet (1.8 specific) has a cold start injector that is vaccuum operated. It is located under the fuel plenum towards the front of the motor (look between the dizzy and the plenum) find the injector and unplug it. If this fixes the problem the issue is most likely either a ground fault or a bad diaphragm. I'll see if I can find you a pic. Good luck, Rick |
Kirmizi |
Mar 27 2010, 07:48 PM
Oooooooooh, that changes everything! (IMG:style_emoticons/default/biggrin.gif)
Mike |
Brandi |
Mar 27 2010, 07:52 PM
Mike -- how does this change everything?? (IMG:style_emoticons/default/sad.gif) Should I not bother with taking the pedal board off? And thanks for all the advice -- I appreciate it! Bloody car is a pain in the a$$, but I just love it, anyway! |
Kirmizi |
Mar 27 2010, 07:59 PM
The throttle cable's the same, check both ends: under the pedal board and where it connects to the throttle body. I'd also make sure the ground strap between the transmission and body is present and in good shape. If it's missing or bad, your throttle cable becomes the ground and it melts into the sheath...
Don't ask me how I know. Mike |
Tom |
Mar 27 2010, 08:29 PM
I think what Mike was refering to was ( is it carbs or FI). Depending on what you have, some of the troubleshooting will be totally different.
Have some one see if the throttle assy. on the engine follows the pedal movement. If so, then the problem is not your pedal or cable. Instead, since you have fuel injection, you probably need to check out things on the FI that can cause high RPMs. 1.8's = L-jet? And if I remember correctly, vacuum leaks on L-jet can cause high RPMs. Tom |
PeeGreen 914 |
Mar 28 2010, 11:59 AM
(IMG:style_emoticons/default/confused24.gif) Did you look at the pedal cluster yet?
Lo-Fi Version | Time is now: 17th May 2024 - 02:48 PM |
