My Trailer Hitch Receiver, and.....kayak carrier |
Joe Owensby |
Mar 30 2010, 10:14 PM
JoeO Group: Members Posts: 527 Joined: 7-January 06 From: Spartanburg, SC Member No.: 5,385 Region Association: South East States |
Here are some photos of my trailer hitch, along with some of my kayak carrier. My hobby is whitewater kayaking in the NC and Tn mountains. With this setup, I can enjoy the drive to the rivers as well as the time spent on the rivers. I made a 1 1/4" tubular hitch receiverfor a trailer hitch. This can hold a trailer ball, a bike rack, or the rig I show to hold up the back of the kayaks. The reciever is supported on the rear by the two bars that I bent up to hug the rear of the car, and go beneath the bumper. These are shown in the photo. The inside of the tube is welded to a 2" by 1/2" inch bar that I heated and bent to follow the underside of the trunk up to the point below the center trunk reinforcement, where I have it bolted through the trunk floor. I cut a notch in the sheet metal heat shield for the muffler to allow this bar to hug the trunk floor. This bar then easily clears a stock muffler, tranny, etc. I notched out the back valence to clear the receiver tube. For the front kayak support, I made two aluminum receiver blocks that bolt into the existing tapped holes under the roll bar. These blocks have a notch cut into them that accepts a 3/4 inch square tubular element which is held in place by a simple quick lock 1/4 inch pin. I leave the blocks on all the time. The pins are pulled to allow the crossbar to be simply removed. Works great, carrying up to two kayaks. I was curious to see if the wind from trucks, etc. would cause any problems when I was going down the road at 70 or so. But, no problems. JoeO |
Joe Owensby |
Mar 30 2010, 10:17 PM
Other photos. Note in the rear view that the rear upward tubing members are not symmetrical. I bent the curves using a pair of trees to hold the1" square aluminum tube while I bent them by pushing as hard as I could. I couldn't get the curves to exactly fit, so I made the attachments to fit the uprights. Note that this arrangement allows full access to the trunk and engine compartment while boats are loaded. It also allows removal of the top if desired. JoeO
Attached thumbnail(s) Attached image(s) |
arkitect |
Mar 30 2010, 11:21 PM
Senior Member Group: Members Posts: 617 Joined: 3-March 10 From: Stockton, CA Member No.: 11,426 Region Association: None |
Pretty cool setup. Never thought I'd see a trailer hitch on a 914.
Dave |
jt914-6 |
Mar 31 2010, 06:12 AM
Driving & working on teeners 41 years Group: Members Posts: 1,785 Joined: 3-May 08 From: Bryant, Arkansas Member No.: 9,003 Region Association: South East States |
Nice setup...I see you are using the "ski rack" mounting threaded holes underneath the targa bar. I'll bet most 914 owners don't even know they are there....
Semi-related....my receiver hitch cover....."show what you tow" |
GaroldShaffer |
Mar 31 2010, 07:00 AM
You bought another 914? Group: Benefactors Posts: 7,620 Joined: 27-June 03 From: Portage, IN Member No.: 865 Region Association: None |
Nice setup. Like the color of the 914 also. (IMG:style_emoticons/default/smilie_pokal.gif)
Sorry (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/hijacked.gif) I have a hidden hitch on my 914 behind my rear plate to pull my AX trailer. Attached image(s) |
EdwardBlume |
Mar 31 2010, 09:45 AM
914 Wizard Group: Members Posts: 12,338 Joined: 2-January 03 From: SLO Member No.: 81 Region Association: Central California |
Both are friggen awesome! Nice work!
zymurgist |
Mar 31 2010, 09:55 AM
"Ace" Mechanic Group: Members Posts: 7,411 Joined: 9-June 05 From: Hagerstown, MD Member No.: 4,238 Region Association: None |
KELTY360 |
Mar 31 2010, 10:46 AM
914 Neferati Group: Members Posts: 5,031 Joined: 31-December 05 From: Pt. Townsend, WA Member No.: 5,344 Region Association: Pacific Northwest |
Nice work. I like that you can still take the top off. Here's my crude but effective method.
EdwardBlume |
Mar 31 2010, 11:55 AM
carr914 |
Mar 31 2010, 12:31 PM
Racer from Birth Group: Members Posts: 118,309 Joined: 2-February 04 From: Tampa,FL Member No.: 1,623 Region Association: South East States |
KELTY360 |
Mar 31 2010, 12:45 PM
Nice work. I like that you can still take the top off. Here's my crude but effective method. I'd be afraid of the two strap method... myself.. Kayak the Snoqualmie or Skykomish? Neither - it's not a whitewater boat. I just use the 2 straps for the 2 mile drive to a put-in on Lk Washington. For longer trips it gets tied down front and back. I am planning on customizing a spare top for a more solid arrangement. |
Joe Owensby |
Mar 31 2010, 04:10 PM
I seriously considered doing what Garold did, ie using a tube inside the trunk. I already had made most of the below trunk hardware before I had seen his. The deciding factor was my being able to leave the tag on for quick installs of a hitch bike carrier, etc.
I also seriously considered adding mounts to an old top. I think this would work fine. Years ago I used the foam and rope methods to carry a hang glider. Thanks for the comments. JoeO |
EdwardBlume |
Mar 31 2010, 05:40 PM
Nice work. I like that you can still take the top off. Here's my crude but effective method. I'd be afraid of the two strap method... myself.. Kayak the Snoqualmie or Skykomish? Neither - it's not a whitewater boat. I just use the 2 straps for the 2 mile drive to a put-in on Lk Washington. For longer trips it gets tied down front and back. I am planning on customizing a spare top for a more solid arrangement. Is there still a kayak polo game near Carillon Point? |
1968Cayman |
Mar 31 2010, 07:18 PM
Redacted by Irving Washington Group: Members Posts: 116 Joined: 5-February 10 From: Holly Springs, GA Member No.: 11,332 Region Association: South East States |
Somebody post a pic of a 914 roof-mounted 17 ft. Perception Essence here and I'm in.
KELTY360 |
Mar 31 2010, 07:27 PM
Nice work. I like that you can still take the top off. Here's my crude but effective method. I'd be afraid of the two strap method... myself.. Kayak the Snoqualmie or Skykomish? Neither - it's not a whitewater boat. I just use the 2 straps for the 2 mile drive to a put-in on Lk Washington. For longer trips it gets tied down front and back. I am planning on customizing a spare top for a more solid arrangement. Is there still a kayak polo game near Carillon Point? Never heard of kayak polo. Wouldn't it be kinda hard to replace the divots? |
JTarver |
Apr 11 2010, 11:01 PM
Medium pimpin Group: Members Posts: 54 Joined: 4-April 10 From: Benton Arkansas Member No.: 11,559 Region Association: South East States |
Somebody post a pic of a 914 roof-mounted 17 ft. Perception Essence here and I'm in. Totally doable. Just get a rack for the top, and make yourself a small receiver hitch in the back, with a straight bar and a cradle frame at the top of it to help support the length of the boat. I will be doing one in the future, and I'm gonna make sure I can carry my seayak (16 foot prijon ) with me if need be. Joe |
EdwardBlume |
Apr 12 2010, 08:48 AM
Nice work. I like that you can still take the top off. Here's my crude but effective method. I'd be afraid of the two strap method... myself.. Kayak the Snoqualmie or Skykomish? Neither - it's not a whitewater boat. I just use the 2 straps for the 2 mile drive to a put-in on Lk Washington. For longer trips it gets tied down front and back. I am planning on customizing a spare top for a more solid arrangement. Is there still a kayak polo game near Carillon Point? Never heard of kayak polo. Wouldn't it be kinda hard to replace the divots? The horses do all the work... (IMG:style_emoticons/default/beer3.gif) |
Joe Bob |
Apr 12 2010, 09:05 AM
Retired admin, banned a few times Group: Members Posts: 17,427 Joined: 24-December 02 From: Boulder CO Member No.: 5 Region Association: None |
I had a tube monted in the trunk of the old "Rocket"....got the wierdest looks while towing. Pics are on the site someplace....
stevegm |
Sep 29 2016, 06:40 PM
Advanced Member Group: Members Posts: 2,111 Joined: 14-July 14 From: North Carolina Member No.: 17,633 Region Association: South East States |
These pictures are very helpful. I have a slightly different idea though. Most of these hitches seem based on the square tubing protruding through the rear bulkhead that is just behind the bumper, and then going under or inside the trunk.
Has anybody seen a hitch that is on or through the bumper, and is supported with a large bracket/plate behind the bumper that bolts to the bulkhead, instead of going through it. I don't want to cut a big hole in the bulkhead. And I just need a hitch for a very small trailer. Other ideas? |
914forme |
Sep 29 2016, 06:57 PM
Times a wastin', get wrenchin'! Group: Members Posts: 3,896 Joined: 24-July 04 From: Dayton, Ohio Member No.: 2,388 Region Association: None |
Nope, put a hole in the bulk head for my current build.
Before that I did one that bolted into the bulkhead and came out under the bumper, had a bar that went back t the exhaust hanger on the trans. Don't think I have pictures of it. Pretty easy you can thread a 1/4" steel behind there, I did not run a rear valance with this setup. Towed great, with my tire trailer. |
Lo-Fi Version | Time is now: 1st May 2024 - 07:48 PM |
