| stevegm |
Sep 29 2016, 07:06 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,111 Joined: 14-July 14 From: North Carolina Member No.: 17,633 Region Association: South East States
Nope, put a hole in the bulk head for my current build. Before that I did one that bolted into the bulkhead and came out under the bumper, had a bar that went back t the exhaust hanger on the trans. Don't think I have pictures of it. Pretty easy you can thread a 1/4" steel behind there, I did not run a rear valance with this setup. Towed great, with my tire trailer. Did that previous set up work well? How heavy a trailer did you tow with it? |
| 914forme |
Sep 29 2016, 07:17 PM
Times a wastin', get wrenchin'! ![]() ![]() ![]() ![]() Group: Members Posts: 3,899 Joined: 24-July 04 From: Dayton, Ohio Member No.: 2,388 Region Association: None
Nope, put a hole in the bulk head for my current build. Before that I did one that bolted into the bulkhead and came out under the bumper, had a bar that went back t the exhaust hanger on the trans. Don't think I have pictures of it. Pretty easy you can thread a 1/4" steel behind there, I did not run a rear valance with this setup. Towed great, with my tire trailer. Did that previous set up work well? How heavy a trailer did you tow with it? Worked very well, towed all over Ohio with it going to auto-x. Maybe 400 pounds with trailer, tools, jack, tires and wheels, and beverages. Towed like it was not there, the key is taking the load back to a point that can handle it. Tongue weight was next to nothing babe 75 pounds. I also ran all LED lights, and you will need a light combiner. I just flipped the 4 pole out of the trunk, and closed the lid on them, never had an issue. Get to the paddock, drop the trailer switch wheels, and (IMG:style_emoticons/default/driving.gif) BTW, the tool storage bin, doubled as a cooler for the local cruise in. Fill it with ice and drinks, and your set (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 15th June 2026 - 03:32 AM |
