V8 Radiator Sources |
kyracedog |
Mar 31 2010, 08:44 PM
Newbie Group: Members Posts: 19 Joined: 19-November 05 From: kentucky Member No.: 5,151 |
Ok V8 guys, what type of radiators did you use? I know Renegade sells a kit that works, but $1100 is a budget buster. Already have the dual fans to use, so don't need them.
Looking for ideas/suggestions/sources. Thanks. |
Bruce Hinds |
Mar 31 2010, 11:21 PM
V-8 madness Group: Members Posts: 733 Joined: 27-December 06 From: Port Orchard, WA Member No.: 7,391 Region Association: Pacific Northwest |
Renegade is expensive, yes. But they've done a bunch of reasearch. You'll need more radiator than if it was in a front enging car or truck, so don't undersize. Getting a unit with enough cooling area in the space between the lights is not easy to find. We used to think more rows were better, but it's harder to pass air through 4 rows than three. The newer units use larger tubes and fins that disapate heat better. Getting the air out is more important than getting it in, so puller fans the bigger the better.
All that being said, if you're going to be in a warm climate and want to run A/C, you might copy what Renegade has done or bite the bullet and pop for a system that will work well. Especially if you're going with alluminum heads, you don't want to overheat those suckers. B |
Lo-Fi Version | Time is now: 20th May 2024 - 12:54 PM |
