V8 Radiator Sources |
kyracedog |
Mar 31 2010, 08:44 PM
Newbie Group: Members Posts: 19 Joined: 19-November 05 From: kentucky Member No.: 5,151 |
Ok V8 guys, what type of radiators did you use? I know Renegade sells a kit that works, but $1100 is a budget buster. Already have the dual fans to use, so don't need them.
Looking for ideas/suggestions/sources. Thanks. |
smrz914 |
Apr 1 2010, 02:50 AM
Soon to be brightening the life of the person behind you. Group: Members Posts: 456 Joined: 21-April 03 From: Pleasant Hill, CA or Chico, CA Member No.: 596 |
I got my radiator custom made from Griffin. Renegade uses a double cross flow radiator so that the inlet and outlet are on the same side. Mine is a 2 core but would definitely go 3 core and make it shorter next time. I have had a little trouble with cooling but I think it's mostly due to air bubbles. I also think that I get a cycling of the thermostat opening and closing causing my temp to fluctuate but last time I ran the car everything was perfect. Good luck.
Attached image(s) Attached File(s) Radiator.pdf ( 17.65k ) Number of downloads: 50 |
Lo-Fi Version | Time is now: 20th May 2024 - 07:22 AM |
