V8 Radiator Sources |
kyracedog |
Mar 31 2010, 08:44 PM
Newbie Group: Members Posts: 19 Joined: 19-November 05 From: kentucky Member No.: 5,151 |
Ok V8 guys, what type of radiators did you use? I know Renegade sells a kit that works, but $1100 is a budget buster. Already have the dual fans to use, so don't need them.
Looking for ideas/suggestions/sources. Thanks. |
BIGKAT_83 |
Apr 1 2010, 06:52 AM
Senior Member Group: Members Posts: 1,798 Joined: 25-January 03 From: Way down south Bogart,GA Member No.: 194 Region Association: South East States |
A couple of good radiators to use for the 914 are from Afco and C&R racing.
The afco 80133n is stocked by Summit racing and cost about $250 This is the C&R modified and can be ordered direct from them. A little higher at $325 or so the last time I checked. It comes with a screw in intake hose for the high pressure side. They will also custom build this for any size you need for a little more. Also a good source for the Fans and shroud is a set up from the last Chrysler front wheel drive New Yorkers. These have a dual fan set up on a nice shroud that is a easy mod to fit any radiator. One of the fan motors have a low and high speed winding. Easy to find at the pick and pulls for $20 |
Lo-Fi Version | Time is now: 20th May 2024 - 11:10 AM |
