V8 Radiator Sources |
kyracedog |
Mar 31 2010, 08:44 PM
Newbie Group: Members Posts: 19 Joined: 19-November 05 From: kentucky Member No.: 5,151 |
Ok V8 guys, what type of radiators did you use? I know Renegade sells a kit that works, but $1100 is a budget buster. Already have the dual fans to use, so don't need them.
Looking for ideas/suggestions/sources. Thanks. |
smrz914 |
Apr 1 2010, 02:50 AM
Soon to be brightening the life of the person behind you. Group: Members Posts: 456 Joined: 21-April 03 From: Pleasant Hill, CA or Chico, CA Member No.: 596 |
I got my radiator custom made from Griffin. Renegade uses a double cross flow radiator so that the inlet and outlet are on the same side. Mine is a 2 core but would definitely go 3 core and make it shorter next time. I have had a little trouble with cooling but I think it's mostly due to air bubbles. I also think that I get a cycling of the thermostat opening and closing causing my temp to fluctuate but last time I ran the car everything was perfect. Good luck.
Attached image(s) Attached File(s) Radiator.pdf ( 17.65k ) Number of downloads: 50 |
computers4kids |
Apr 1 2010, 10:02 AM
Love these little cars! Group: Members Posts: 2,443 Joined: 11-June 05 From: Port Townsend, WA Member No.: 4,253 Region Association: None |
I also think that I get a cycling of the thermostat opening and closing causing my temp to fluctuate Several water cooled guys I've met do not run thermostats. Is this because of the "fluctuating" mentioned? I assumed the fluctuating was more about the fans cycling on and off. (IMG:style_emoticons/default/confused24.gif) |
Mike Bellis |
Apr 1 2010, 11:00 PM
Resident Electrician Group: Members Posts: 8,345 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None |
I also think that I get a cycling of the thermostat opening and closing causing my temp to fluctuate Several water cooled guys I've met do not run thermostats. Is this because of the "fluctuating" mentioned? I assumed the fluctuating was more about the fans cycling on and off. (IMG:style_emoticons/default/confused24.gif) My temp cycles too. 150 while driving, 180 sitting still. My fan does not come on below 180. I wish I could keep it at 180 all the time. |
Lo-Fi Version | Time is now: 20th May 2024 - 08:18 AM |
