V8 Radiator Sources |
kyracedog |
Mar 31 2010, 08:44 PM
Newbie Group: Members Posts: 19 Joined: 19-November 05 From: kentucky Member No.: 5,151 |
Ok V8 guys, what type of radiators did you use? I know Renegade sells a kit that works, but $1100 is a budget buster. Already have the dual fans to use, so don't need them.
Looking for ideas/suggestions/sources. Thanks. |
andys |
Oct 26 2010, 09:41 AM
Advanced Member Group: Members Posts: 2,165 Joined: 21-May 03 From: Valencia, CA Member No.: 721 Region Association: None |
100 Amps sounded way too high, so I Googled it and found the following where the article claims that Mk VIII fan draws only 30 Amps (though it doesn't say anything about startup current, but I can't imagine it being more than 3 times higher).
http://www.fordmuscle.com/archives/2006/10/Mark8Fan/ The 30 Amp requirement will not require all those expensive bits. You can buy 30, 40, or 60 (or higher) Amp automotive relays here: http://www.wiringproducts.com/contents/en-...tive-relay.html Andys |
Lo-Fi Version | Time is now: 10th May 2024 - 05:37 AM |
