V8 Radiator Sources |
kyracedog |
Mar 31 2010, 08:44 PM
Newbie Group: Members Posts: 19 Joined: 19-November 05 From: kentucky Member No.: 5,151 |
Ok V8 guys, what type of radiators did you use? I know Renegade sells a kit that works, but $1100 is a budget buster. Already have the dual fans to use, so don't need them.
Looking for ideas/suggestions/sources. Thanks. |
andys |
Oct 26 2010, 09:41 AM
Advanced Member Group: Members Posts: 2,165 Joined: 21-May 03 From: Valencia, CA Member No.: 721 Region Association: None |
100 Amps sounded way too high, so I Googled it and found the following where the article claims that Mk VIII fan draws only 30 Amps (though it doesn't say anything about startup current, but I can't imagine it being more than 3 times higher).
http://www.fordmuscle.com/archives/2006/10/Mark8Fan/ The 30 Amp requirement will not require all those expensive bits. You can buy 30, 40, or 60 (or higher) Amp automotive relays here: http://www.wiringproducts.com/contents/en-...tive-relay.html Andys |
stewteral |
Oct 31 2010, 10:34 PM
Old Member Group: Members Posts: 384 Joined: 4-December 07 From: Camarillo, CA Member No.: 8,424 Region Association: Southern California |
100 Amps sounded way too high, so I Googled it and found the following where the article claims that Mk VIII fan draws only 30 Amps (though it doesn't say anything about startup current, but I can't imagine it being more than 3 times higher). http://www.fordmuscle.com/archives/2006/10/Mark8Fan/ The 30 Amp requirement will not require all those expensive bits. You can buy 30, 40, or 60 (or higher) Amp automotive relays here: http://www.wiringproducts.com/contents/en-...tive-relay.html Andys Hey Andy, As you know, I'm a sales guy in the power electronics world and have learned the start-up inductive load for electric motors can go as high as 6 times normal running current. However, there are a lot of variable, starting with the motor design, wire gauge, operating RPM, the Length of time the Peak current is drawn, etc. There are Slo-Blow fuses available designed to ride-through the current peaks to avoid nuisance "blows", but I have not seen them to be readily available. If the fan is ACTUALLY rated at 30 Amps constant running, rather than "Rated to 30 Amps", I would go with your suggestion of using 60 amp relays and 60 amp circuit breakers from wiring products. Best, Terryu |
Lo-Fi Version | Time is now: 20th May 2024 - 09:52 AM |
