V8 Radiator Sources |
kyracedog |
Mar 31 2010, 08:44 PM
Newbie Group: Members Posts: 19 Joined: 19-November 05 From: kentucky Member No.: 5,151 |
Ok V8 guys, what type of radiators did you use? I know Renegade sells a kit that works, but $1100 is a budget buster. Already have the dual fans to use, so don't need them.
Looking for ideas/suggestions/sources. Thanks. |
Mike Bellis |
Nov 3 2010, 10:27 PM
Resident Electrician Group: Members Posts: 8,345 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None |
If you run lines inside, it WILL get hot. My last one had cooant lines in the center tunnel. Always too hot in the cab. I run them under the car now in the two factory recesses with some 2 hole straps holding it on. It works great. I occasionally bottom out on speed bumps if they are really tall. My car is LOW. Rubber hose will collaps breifly on the bump and open right back up again. No big deal. Hard lines would crush or tear if mounted under the car. If you run lines in the car like the picture, your left foot will always be uncomfortably hot! You will not enjoy driving long distance in the summer as much.
Lo-Fi Version | Time is now: 9th May 2024 - 08:20 PM |
