V8 Radiator Sources |
kyracedog |
Mar 31 2010, 08:44 PM
Newbie Group: Members Posts: 19 Joined: 19-November 05 From: kentucky Member No.: 5,151 |
Ok V8 guys, what type of radiators did you use? I know Renegade sells a kit that works, but $1100 is a budget buster. Already have the dual fans to use, so don't need them.
Looking for ideas/suggestions/sources. Thanks. |
Phoenix-MN |
Nov 4 2010, 04:49 AM
Senior Member Group: Members Posts: 927 Joined: 23-January 04 From: ST. Bonifacius,MN Member No.: 1,590 |
The Subaru motor has 1.25 ID, 1.5 OD lines coming off the motor and the whole thing is pressurized. I was considering running 1.5" OD, 0.058" wall thickness aluminum pipes. Does anyone have any pictures of their set-ups? -Britain 1.25" and 1.5" Stainless under the car, pictures at: http://phoenixhobbies.com/html/cooling.html Paul |
Mike Bellis |
Nov 4 2010, 01:17 PM
The Subaru motor has 1.25 ID, 1.5 OD lines coming off the motor and the whole thing is pressurized. I was considering running 1.5" OD, 0.058" wall thickness aluminum pipes. Does anyone have any pictures of their set-ups? -Britain 1.25" and 1.5" Stainless under the car, pictures at: http://phoenixhobbies.com/html/cooling.html Paul I must admit the aluminum looks like top notch work. I would still be a little afraid of grinding over time that could lead to failure. |
Lo-Fi Version | Time is now: 20th May 2024 - 07:04 AM |
