N 010.207.6, Hex Bolt |
Posts in this area are restricted to the following format. If you have a general question, please post it in the Garage.
1. All new threads MUST be titled with a part number only. (i.e. 901.351.801.17)
2. Thread description should be an english description of the part. (i.e. Brake Dust Shields)
3. Replies to the thread are only restricted by pertinence. Some examples are original finish of the part (painted, cad plated, etc), common failures (cracking at the mount points), repair information or tips, pictures (stock or custom), upgrades, etc.
If you have any questions regarding the rules of this forum, please PM McMark.
McMark |
Apr 2 2010, 10:19 PM
PET Illustration 905-03, item #30.
These are the small bolts that hold the fuel tank sender to the fuel tank. There are 5mm x 0.80 x 12mm. They are steel and originally finished in cad plating or yellow zinc plating. Original manufacturing stampings could be either DORN or FHS. Need more research to finalize, or perhaps a variety of manufacturers were used depending on availability. Attached image(s) |
Lo-Fi Version | Time is now: 18th May 2024 - 07:13 AM |
