| McMark |
Apr 7 2010, 10:33 AM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,180 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None |
https://www.youtube.com/watch?v=CUdPmitJ9XQ Took this video to post in my "Hold the phone!" build thread, but for those who might miss it, this is a repost. |
| ConeDodger |
Apr 7 2010, 10:42 AM
Apex killer! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,631 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Rocky Mountains
Holy Moly! Don't we have a member vendor that has a weld in and bolt in brace?
| ChrisFoley |
Apr 7 2010, 10:51 AM
I am Tangerine Racing ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,033 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None
I think I read that the bolt-in brace is no longer being made.
Some lucky WCR attendee may be receiving one of the weld-in braces though. (IMG:style_emoticons/default/smile.gif) |
| rick 918-S |
Apr 7 2010, 10:57 AM
Hey nice rack! -Celette ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 21,367 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region
Fix your floor pan. It's cracked around the brace. Oh, then add the brace.
| McMark |
Apr 7 2010, 11:07 AM
Eh? (IMG:style_emoticons/default/blink.gif)
I didn't see no cracking. (IMG:style_emoticons/default/confused24.gif) |
| underthetire |
Apr 7 2010, 11:10 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,062 Joined: 7-October 08 From: Brentwood Member No.: 9,623 Region Association: Northern California |
Holly crap ! Think i'll make a support after seeing that.
| Root_Werks |
Apr 7 2010, 11:14 AM
Village Idiot ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,076 Joined: 25-May 04 From: About 15NM from Canada Member No.: 2,105 Region Association: Pacific Northwest
| rick 918-S |
Apr 7 2010, 11:19 AM
Eh? (IMG:style_emoticons/default/blink.gif) I didn't see no cracking. (IMG:style_emoticons/default/confused24.gif) Look around the curve of the brace as the master flexes. The brace is stable and the pan moves. I think I can even see light around it. I could be wrong... |
| SirAndy |
Apr 7 2010, 11:20 AM
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,552 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
you'll be surprised Nope ... I've seen this many times. They all flex. (IMG:style_emoticons/default/shades.gif) Back in the old days, people welded a boxed section around the back of the mounting area. Lots of work and ugly, but effective. The clamp-on solution worked, but didn't seem 'right'. I've been thinking about welding a tab on the steel cross-member that would allow you to bolt on a support bracket under the MC. That way, if you need to replace the MC, you can just unbolt the bracket. (IMG:style_emoticons/default/popcorn[1].gif) Andy |
| SirAndy |
Apr 7 2010, 11:22 AM
Look around the curve of the brace as the master flexes. The brace is stable and the pan moves. I think I can even see light around it. I could be wrong... The metal flexes, but not because it's cracked. It's just a single layer of sheet-metal that will bend every time you hit the brakes. All stock 914s do that ... (IMG:style_emoticons/default/shades.gif) Andy |
| ericread |
Apr 7 2010, 11:28 AM
The Viper Blue 914 ![]() ![]() ![]() ![]() Group: Members Posts: 2,177 Joined: 7-December 07 From: Irvine, CA (The OC) Member No.: 8,432 Region Association: Southern California |
There was also a bolt-on brace offered previously (I have no welding skills/eqiuipment). I have looked around but I cannot find it for sale anywhere. If anyone wants to make one, I'm first in line to purchase.
Eric |
| McMark |
Apr 7 2010, 12:25 PM
Rick, the factory bracing/box which is under the pedal assembly is open on the forward face. That crack you're seeing is just how it is.
This is the 'repair' that I've seen done by another 914 guy. Weld a nut to the cross member and thread a bolt against the MC to brace it. It helps, but not as much as I would like. Time to try something else. https://www.youtube.com/watch?v=d02D8jRn7T0 |
| McMark |
Apr 7 2010, 03:01 PM
Well, here's what it took to get it immobile. A sturdy brace in the vertical direction via a bar that bolts to the MC mount studs at one end and to a welded nut on the cross member. But this brace still moved forward and back, so I had to bring my original 'fix' back into contact with the MC to restrict horizontal movement. The other modifications I tried, still allowed some movement at the MC and didn't feel much more firm at the pedal. After getting this all done, the difference would pronounced at the pedal.
This is all rather ugly, so now I'll go back and replace everything with a cleaner, prettier setup. https://www.youtube.com/watch?v=iIvAyozXx4Y |
| rick 918-S |
Apr 7 2010, 03:09 PM
Ya, I know the brace is open. I was looking at the stamped edge. Must be the lighting. Glad it's not cracked. Your brace is working well.
| McMark |
Apr 7 2010, 03:11 PM
There is one of those U-slits under the pedal cluster. You know, the ones that are all over the floor pan. So there is light coming through there, but it's not rust or cracking. It's just factory holes. (IMG:style_emoticons/default/wacko.gif)
| Root_Werks |
Apr 7 2010, 03:16 PM
That's a good fix!
When mine's up in the air, I'll do something similar for sure. (IMG:style_emoticons/default/welder.gif) |
| rick 918-S |
Apr 7 2010, 04:15 PM
There is one of those U-slits under the pedal cluster. You know, the ones that are all over the floor pan. So there is light coming through there, but it's not rust or cracking. It's just factory holes. (IMG:style_emoticons/default/wacko.gif) OH! I knew I saw light! That's right! Anywho... Nice brace! |
| veltror |
Senior Member ![]() ![]() ![]() Group: Members Posts: 930 Joined: 27-April 08 From: Potters Bar Herts UK Member No.: 8,978 Region Association: None |
My floor is rotten so Marek is making up a triple skinned piece as in my thread...
| brant |
Apr 7 2010, 07:15 PM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,282 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains
fixing the flex is a good thing
it will help firm up the "feel" we did this on our old car about 15 years ago and on the new one when we built it 6 years ago also here is the new ones method with lightening holes: Attached thumbnail(s) |
| brant |
Apr 7 2010, 07:16 PM
and:
Lo-Fi Version | Time is now: 26th October 2026 - 11:47 PM |
