/6 wiring, Want to figure this one out (with help) |
PanelBilly |
Apr 11 2010, 10:28 AM
914 Guru Group: Members Posts: 5,804 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest |
I want to figure out the engine harness for my 3.0 but I'm looking for some assistance. Here's the stats
I have the original harness from the 3.0 Engine did have CIS, but I'm converting to carbs Internal regulator No relay board All the connectors I have are broken including the one that connects from the body harness to the relay board I want the cleanest wiring connection from the car to the engine I can get. Since my connectors are all crap, should I convert to another style of connector or stick with the OEM style since the pins are still on the ends of the wires. Just what do I need to wire up? The starter and the altenator and gauges? What lines need relays and do I use the relay connectos from the headlights or has someone come up with a better idea? |
JeffBowlsby |
Apr 11 2010, 11:04 AM
914 Wiring Harnesses Group: Members Posts: 8,492 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Perry Keihl or Patrick Motorsports has the solution for you.
IronHillRestorations |
Apr 12 2010, 07:09 AM
I. I. R. C. Group: Members Posts: 6,716 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
The factory connectors are going to run you around $85 for the pair you need, unless you can scrounge a salvage connector for your body wiring harness.
Lo-Fi Version | Time is now: 8th May 2024 - 11:39 PM |
