Elephant Poly Bronze Bushing binding, fore / aft binding on front control arm |
bobhasissues |
Apr 12 2010, 08:23 AM
seemingly endless issues with my 914 Group: Members Posts: 218 Joined: 13-February 07 From: Chicagoland Member No.: 7,532 Region Association: None |
Installed the poly bronze front bushings and noticed I have some binding, more so on the passneger side. No front end damage. The binding seems to be a fore / aft problem rather than an axis problem. I have pushed both front and rear mounts as far out as they will go. It seems the only solution is to extend the length of the openings on the front mounts to allow some more room for the bushings to move freely. Is this a reasonable solution? Has anyone else had this problem, and how did you resolve it?
PeeGreen 914 |
Apr 12 2010, 08:52 AM
Just when you think you're done...wait, there is more..lol Group: Members Posts: 10,219 Joined: 21-September 06 From: Seattle, WA... actually Everett Member No.: 6,884 Region Association: Pacific Northwest |
This problem is fairly common. Elephant does sell a solution that helps make this easy but you can do it on you own if you want to take the time. It consists of stacking spacers to make everything even. You NEED to get these at zero bind.
realred914 |
Apr 12 2010, 09:33 AM
Senior Member Group: Retired Members Posts: 1,086 Joined: 1-April 10 From: california Member No.: 11,541 Region Association: None |
yes spherical spacers are sued to even it up. takes a bit ot doing to get it right, but they shouldnot bind. we found spoacers totaly needed to get smooth running.
once doen they are nice, but there are a royal pain to get to that point. once done you should be happy |
PeeGreen 914 |
Apr 12 2010, 10:18 AM
Eric_Shea |
Apr 12 2010, 11:51 AM
PMB Performance Group: Admin Posts: 19,274 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
QUOTE yes spherical spacers are sued to even it up. takes a bit ot doing to get it right, but they shouldnot bind. we found spoacers totaly needed to get smooth running. once doen they are nice, but there are a royal pain to get to that point. once done you should be happy Is this English? (IMG:style_emoticons/default/biggrin.gif) |
Ericv1 |
Apr 12 2010, 05:33 PM
Member Group: Members Posts: 259 Joined: 30-December 07 From: Cincinnati, Ohio Member No.: 8,518 Region Association: Upper MidWest |
QUOTE yes spherical spacers are sued to even it up. takes a bit ot doing to get it right, but they shouldnot bind. we found spoacers totaly needed to get smooth running. once doen they are nice, but there are a royal pain to get to that point. once done you should be happy Is this English? (IMG:style_emoticons/default/biggrin.gif) Blackberry English! |
Krieger |
Apr 12 2010, 06:37 PM
Advanced Member Group: Members Posts: 4,705 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
For my car what I found helpful was to turn the front bearing retainers upside down. One side has a welded on washer that normally faces the body. My washers face away from the body.
Eric_Shea |
Apr 12 2010, 07:00 PM
Andy, that could leave your control arm to rub the body at the lip of the front flange.
tradisrad |
Apr 12 2010, 07:07 PM
I mimicked the Elephant low friction mount. I added a longer bolt and 4 sets of self aligning washers to the front mounts .
This is just one of the 4 front bolts: And on the rear mounts I machined the mount down to accomidate the self aligning washers on the top and bottom of each mount. Here is a picture of the bottom of one mount: The self aligning washers cost about $50 for all 12 sets (8 front and 4 rear). It still took some fiddling to get the arm just right, but not too much. I was mostly concerned with the movement in the suspension travel range. I must say that stainless washers may hold up better than the ones I put in. Looking at my pictures my washers seem to have some rust and it has only been 9 months. BTW I bought the washers from fastenal and on some other post I provided links (it may have been on the Club site). Did I say that I love the bushings and my 914 is smoother than my Subaru! |
Krieger |
Apr 12 2010, 08:10 PM
Ooooh, Eric you made me check my work. They moved freely (dropped under their own weight) while in the air. No grinding sounds. I just looked and slid a pile of post it notes (like a feeler gauge) all the way the lenght of both arms. No less than 2mm clearance. (IMG:style_emoticons/default/biggrin.gif)
orange914 |
Apr 12 2010, 08:28 PM
http://5starmediaworks.com/index.html Group: Members Posts: 3,371 Joined: 26-March 05 From: Ceres, California Member No.: 3,818 Region Association: Northern California |
QUOTE yes spherical spacers are sued to even it up. takes a bit ot doing to get it right, but they shouldnot bind. we found spoacers totaly needed to get smooth running. once doen they are nice, but there are a royal pain to get to that point. once done you should be happy Is this English? (IMG:style_emoticons/default/biggrin.gif) Blackberry English! carefull! bobhasissues |
Eric_Shea |
Apr 12 2010, 09:17 PM
QUOTE Ooooh, Eric you made me check my work. They moved freely (dropped under their own weight) while in the air. No grinding sounds. I just looked and slid a pile of post it notes (like a feeler gauge) all the way the lenght of both arms. No less than 2mm clearance. Cool. Sorry for the extra work. probably more of an issue with a rubber bushing in there. Just wanted to make sure. (IMG:style_emoticons/default/wink.gif) Carry-On! (IMG:style_emoticons/default/biggrin.gif) |
Krieger |
Apr 13 2010, 08:42 AM
Awareness is good. Thirty seconds of my life down the shitter oh well. I work up a little early today to make up for it.
Lo-Fi Version | Time is now: 8th May 2024 - 04:32 AM |
