Noob question.. how far do I fill the brake res? |
tod914 |
Apr 12 2010, 03:28 PM
Redid my blue brake lines this past fall and forgot what the fluid level was in the resevoir. How far do I top it off? Thanks.
VaccaRabite |
Apr 12 2010, 03:44 PM
En Garde! Group: Admin Posts: 13,441 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
'Till its full.
I fill mine up to the top. Zach |
Tom_T |
Apr 12 2010, 03:56 PM
Redid my blue brake lines this past fall and forgot what the fluid level was in the resevoir. How far do I top it off? Thanks. Just to the max line on the bottle/res. (if it has one), otherwise or instead just 1/16" - 1/8"shy of the flat top of the res. You don't want heat, atmospheric changes nor braking action to force any fluid out around the seal & onto your beauty there! (IMG:style_emoticons/default/biggrin.gif) Break Fluid EATS paint, plating, etc.! (IMG:style_emoticons/default/sad.gif) That's after you've bleed down the system & removed any air bubbles, so you have a constant fluid level in the res. that is!! |
tod914 |
Apr 12 2010, 08:05 PM
Thanks guys, much appreciated.
Lo-Fi Version | Time is now: 9th May 2024 - 08:18 AM |
