> Wonky headlight..., back again (post 17)
VaccaRabite
post Apr 13 2010, 07:45 AM
En Garde!
Last fall, the drivers side headlight went out. it was miswired - I am not sure how it was working to begin with. Fixed the wiring, and everything worked great.
Saturday I washed my car.
Today, I decided to drive to work, even though rain was threatening, weather said I would be clear. But it was cloudy this morning, so I put the lights on. I got no beam from the drivers side light, again.
Also, I noticed that the charging system was right at 12 volts, where it is usually at 13. May be unrelated.
I know that the wiring at the light is correct. Any idea where to start trouble shooting?
Zach
Vacca Rabite   Wonky headlight...   Apr 13 2010, 07:45 AM
tradisrad   I also see a voltage drop when my lights are on fr...   Apr 13 2010, 07:49 AM
underthetire   I've had a problem with my old sealed beams be...   Apr 13 2010, 11:11 AM
jsayre914   dont woory about the voltage drop zach, it isnt a ...   Apr 13 2010, 12:07 PM
Vacca Rabite   Mike may be over today. He was planning on being o...   Apr 13 2010, 12:10 PM
TROJANMAN   Did you check the relay?   Apr 13 2010, 12:20 PM
Drums66   Did you check the relay? ECHO echo(also headlig...   Apr 13 2010, 12:43 PM
Vacca Rabite   Not yet. Noticed the light was out when I pulled ...   Apr 13 2010, 12:24 PM
Spoke   Start checking voltages right at the light. If yo...   Apr 13 2010, 02:32 PM
Vacca Rabite   When I got home tonight I took a few minutes to tr...   Apr 13 2010, 07:03 PM
Dave_Darling   Sounds like the brighter light is grounding itself...   Apr 13 2010, 09:10 PM
Vacca Rabite   Dave, I considered this. I think it is probably t...   Apr 14 2010, 06:06 AM
Vacca Rabite   Okay, so new puzzle. I fixed the first problem. ...   Apr 16 2010, 08:41 PM
Dave_Darling   How did you measure the voltage? Between which an...   Apr 16 2010, 09:20 PM
Vacca Rabite   I measured voltage at the headlight terminals. Wh...   Apr 17 2010, 06:52 AM
Vacca Rabite   Well, Mike helped me chase the problem, and we fou...   Apr 19 2010, 08:08 AM
Vacca Rabite   So, this problem still exists. I had been letting...   May 24 2010, 09:47 PM
Spoke   Low beams are only getting 6 volts at the bulb. ...   May 25 2010, 11:12 AM
Dr Evil   Maybe I can help you out sometime :rolleyes:   May 24 2010, 11:06 PM
Vacca Rabite   Maybe I can help you out sometime :rolleyes: Did...   May 25 2010, 06:29 AM
Dr Evil   I remember nothing. I would have to start at it so...   May 25 2010, 09:41 AM
Vacca Rabite   One test that I am going to do this evening, which...   May 25 2010, 01:11 PM
Vacca Rabite   Just finished my wire test. Everything from the fu...   May 25 2010, 06:20 PM
Dr Evil   I may have a spare. I know where I can get one, an...   May 25 2010, 06:45 PM
Spoke   Disconnect NEG from Battery and pull out your swit...   May 25 2010, 08:38 PM
Vacca Rabite   I'm back inside for the night, and I made prog...   May 25 2010, 08:57 PM
Spoke   I wouldn't expect a rubbed wire or anything li...   May 25 2010, 10:11 PM
Vacca Rabite   I'll clean them tonight and report back. I am ...   May 26 2010, 06:49 AM
- Lo-Fi Version Time is now: 17th September 2026 - 02:18 AM
