Fuel Injection Options, just getting some info ahead of time |
buhs914 |
Apr 15 2010, 12:00 AM
Not So Newbie Group: Members Posts: 331 Joined: 16-June 09 From: Buckeye, AZ Member No.: 10,478 Region Association: Southwest Region |
So i would like to switch out my weber progressive carb on my '73 for fuel injection. I was wondering what type of fuel injection would be the best quality for a decent price?
Porcharu |
Apr 15 2010, 01:06 AM
Senior Member Group: Members Posts: 1,314 Joined: 27-January 05 From: Campbell, CA Member No.: 3,518 Region Association: Northern California |
Take a look here - http://www.914world.com/bbs2/index.php?sho...p;hl=megasquirt
Really the only way to go for a decent price - ie under $1000. Steve |
buhs914 |
Apr 15 2010, 01:13 AM
Take a look here - http://www.914world.com/bbs2/index.php?sho...p;hl=megasquirt Really the only way to go for a decent price - ie under $1000. Steve Ok cool. How do i go about getting it? Also, how easy is it to install? |
Joe Owensby |
Apr 15 2010, 01:47 AM
JoeO Group: Members Posts: 527 Joined: 7-January 06 From: Spartanburg, SC Member No.: 5,385 Region Association: South East States |
Not the cheapest, but SDS makes a unit that is recommended by almost everyone that uses it. I have had one for about 2 years now, and it has worked great. The hardest part of the install was obtaining and installing the manifold and stiff. Here are details.
http://www.914world.com/bbs2/index.php?sho...=92241&st=0 JoeO |
buhs914 |
Apr 15 2010, 01:54 AM
Not the cheapest, but SDS makes a unit that is recommended by almost everyone that uses it. I have had one for about 2 years now, and it has worked great. The hardest part of the install was obtaining and installing the manifold and stiff. Here are details. http://www.914world.com/bbs2/index.php?sho...=92241&st=0 JoeO hmm well i would definitely check into that if i had the money.. but i need something cheaper and efficient. |
type47 |
Apr 15 2010, 06:42 AM
Cheap could include an L-Jet system. I might recommend not getting a 73 D-Jet system as it needs a unique to 73 MPS whereas a 74 D-Jet might interchange some parts with other years.
realred914 |
Apr 15 2010, 09:33 AM
Senior Member Group: Retired Members Posts: 1,086 Joined: 1-April 10 From: california Member No.: 11,541 Region Association: None |
d-jet
underthetire |
Apr 15 2010, 09:54 AM
Cheapest would be a megasquirt, but you would still need to source a stock plenum/runners/fuel injectors/fuel pump/throttle body, so at that point you might as well throw a complete Djet on. And as a bonus, the Djet won't need to be programmed.
benalishhero |
Apr 15 2010, 10:05 AM
Member Group: Members Posts: 313 Joined: 28-November 07 From: Portland, Maine Member No.: 8,384 Region Association: North East States |
I would also go with stock D-jet. I got my system running very well for about $350 with a mix of used and new parts.
rsrguy3 |
Apr 15 2010, 11:09 AM
Member Group: Members Posts: 136 Joined: 4-April 09 From: Utah Member No.: 10,234 Region Association: None |
I did this to my 74 2l, I had to source all of the original fuel injection bits, a brain, relay board, injectors, and a wideband. It ended up costing around a grand. If you look around you might be able to find all the bits for less, but it will be tough to find a wideband for less than 250$, a brain for around 300$ and a relay board for 80, not to mention the relay/brain cable. PM James on that poll for more info. Mine started right up and ran quite well, right off with no drama(I hate drama). I drove around quite a bit, and we got it dialed in pretty well when I discovered some other issues that need to be delt with before the car see's more road time. The bottom line.... you'll need about a 1000$ to do the MS if you don't have the injection set up already.
pbanders |
Apr 15 2010, 12:37 PM
Senior Member Group: Members Posts: 939 Joined: 11-June 03 From: Phoenix, AZ Member No.: 805 |
If your 1.7L is stock, a D-Jet setup would require the least engineering on your part, it's mostly bolt-on. You can find out what components you need from my website (see sig.)
buhs914 |
Apr 15 2010, 12:40 PM
If your 1.7L is stock, a D-Jet setup would require the least engineering on your part, it's mostly bolt-on. You can find out what components you need from my website (see sig.) That's what i was looking at. I'd like to go with the stock system since it's made for the car... |
azbill |
Apr 15 2010, 12:52 PM
Member Group: Members Posts: 455 Joined: 26-July 04 From: Glendale, Az Member No.: 2,403 Region Association: Southwest Region |
D-jet is the simplest way to go. Mega-Squirt as well as other programmable systems can be a total pain. I have a Emerald M3D the programming was the most trouble some and expensive.
Lo-Fi Version | Time is now: 9th May 2024 - 12:31 PM |
