Installing Hella horn relay? |
Geezer914 |
Apr 15 2010, 02:42 PM
Geezer914 Group: Members Posts: 1,393 Joined: 18-March 09 From: Salem, NJ Member No.: 10,179 Region Association: North East States |
Any one replace the original horns with Hella horns? How do I replace the original horn relay with the Hella horn relay. Looking for a wireing diagram.
dr914@autoatlanta.com |
Apr 15 2010, 02:57 PM
914 Guru Group: Members Posts: 7,840 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
Any one replace the original horns with Hella horns? How do I replace the original horn relay with the Hella horn relay. Looking for a wireing diagram. The 914 already has a horn relay so there is no need to install another. Only when you are adding the Hella AIR horns do you have to install an extra part, a compressor. |
VaccaRabite |
Apr 15 2010, 05:41 PM
En Garde! Group: Admin Posts: 13,441 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
I disagree.
You need to install the relay. I put a set of Hella Supertones on my car. At first I did not use the relay. When you hit the horns, you could hear them slowly get louder until they were at full volume. When I got smart and added the relay, and then hit the horns, they were instantanious, and a lot louder then they were pre-relay. I ran the relay back directly to the hot terminal of the battery, with a fuse in line. Zach |
Lo-Fi Version | Time is now: 9th May 2024 - 01:54 AM |
