| GTeener |
Apr 28 2010, 03:59 PM
914 Girl ![]() ![]() ![]() ![]() Group: Members Posts: 2,348 Joined: 25-June 04 From: SillyCon Valley Member No.: 2,249 Region Association: Northern California |
May this be a lesson to us all (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/headbang.gif)
Driving from Fair Oaks/Sacramento to Vacaville last Sunday. Filled the tank up before leaving town (1/2 tank of Premium gas). During freeway drive, started noticing and getting concerned by the rising oil temp and falling oil pressure. Peaked at 260+ oil temp and the 30 psi oil pressure reading on the gauges. The engine made a sputter crackle sound like it was running rich at one point in slow traffic at the Hwy 50 & Hwy 80 merge. There was a puff of dark smoke upon acceleration. The engine didn't stop sputtering and there's been a knocking sound ever since, but there's no dark smoke. Lost my go power too. Feels like it isn't in the proper gear or something. Possibly missing a cylinder?? I stopped for lunch in Davis to let the engine cool off and stretch the dog. Drove some more without any noticeable improvement in the temp or power situation. Stopped at a 76 station in Vacaville to look more closely. There is oil in the tank and it looks clean, but the level is above the fill dot. No distributor wires are loose. Engine bay looks clean...No obvious oil leaks/spray. Got flatbed towed the rest of the way home by AAA. Best I can tell, the oil may not be circulating properly. Best guess is that the thermostat isn't opening or there is a block in the oil cooler line somewhere but don't know why. Leamon Stansell (HealToe914) did the oil cooler setup work in May 2007 (pictures below). The car hadn't been driven much since. Half the tank of gas was 7 mos old (Premium) when I hit the freeway on Sunday. Waiting for Rich Walton at Jerry Woods Enterprises to give me the go ahead to have the car towed to them for further diagnosis and repair but thought it *might* be worth getting *the group's* opinions/experiences on the subject. Attached image(s)
GTeener My front oil cooler setup -- why's it failing? Apr 28 2010, 03:59 PM
Cap'n Krusty You simply CANNOT use camshafts with CIS. While i... May 25 2010, 12:37 PM
SLITS
You simply CANNOT use camshafts with CIS. While ... May 25 2010, 12:46 PM
GTeener
You simply CANNOT use camshafts with CIS. While... May 25 2010, 01:52 PM
SLITS Gwen, the other point in this whole thing is that ... May 25 2010, 02:33 PM
ArtechnikA
Most everyone I know will question a mechanics ab... May 25 2010, 03:59 PM
GTeener
Most everyone I know will question a mechanics a... May 25 2010, 04:49 PM
BigDBass :popcorn: Future classic thread?
Very educational ... May 25 2010, 02:42 PM
J P Stein There is $2k+ worth of parts from that old mo... May 25 2010, 04:49 PM
GTeener These are the core parts he is crediting me ... May 25 2010, 05:50 PM
ArtechnikA
These are the core parts he is crediting me ... May 25 2010, 05:58 PM
GTeener These are the parts for the CIS conversion (no cam... May 25 2010, 06:01 PM
GTeener close up of a CIS head replacement Tom's plann... May 25 2010, 06:02 PM
GTeener The set of CIS heads to be used May 25 2010, 06:04 PM
GTeener The following pictured were grabbed from the video... May 25 2010, 06:09 PM
GTeener badly scraped aka broken bearing May 25 2010, 06:11 PM
GTeener connecting rods (bearings in the back) May 25 2010, 06:12 PM
GTeener rod in hand :) May 25 2010, 06:14 PM
GTeener crankshaft May 25 2010, 06:15 PM
GTeener oil pump, crankshaft, half case, connecting rods (... May 25 2010, 06:17 PM
GTeener bearing shell scuffs May 25 2010, 06:18 PM
GTeener more bearing shell scuffs elsewhere May 25 2010, 06:19 PM
GTeener scuffed piston May 25 2010, 06:20 PM
GTeener another bearing starting to wear May 25 2010, 06:21 PM
GTeener pistons and cylinders (front right has some cruft ... May 25 2010, 06:23 PM
GTeener fly's eye view of pistons & cylinders :D May 25 2010, 06:26 PM
GTeener I think I recall Tom saying this case screw was a ... May 25 2010, 06:28 PM
GTeener engine oil cooler (says he'll may replace this... May 25 2010, 06:30 PM
GTeener case half wear overview May 25 2010, 06:34 PM
brant Gwen,
I'm no expert
but my guess is with all... May 25 2010, 07:32 PM
GTeener Perhaps.
Tom said there also appears to be too muc... May 25 2010, 07:45 PM
elmonte Is this teflon tape? Not something you want floati... May 25 2010, 10:36 PM
SLITS Ok Gwen ... here's the marking on pistons ... May 26 2010, 08:56 AM
GTeener Thanks Ron. I'll have to look more closely bef... May 26 2010, 10:56 AM
GTeener OK, so now that ya'll've seen the parts, t... May 26 2010, 10:58 AM
ArtechnikA
OK, so now that ya'll've seen the parts, ... May 26 2010, 12:41 PM
GTeener
OK, so now that ya'll've seen the parts,... May 26 2010, 05:39 PM
Dr Evil :agree: I have been watching and trying to figure ... May 26 2010, 01:42 PM
SLITS
:agree: I have been watching and trying to figure... May 26 2010, 02:54 PM
GTeener :idea: In order to sell my MFI "complete... May 26 2010, 02:11 PM
ArtechnikA
:idea: In order to sell my MFI "complete... May 26 2010, 02:35 PM
GTeener FWIW -- Tom is not experimenting with my rebuild.
... May 26 2010, 02:17 PM
Dr Evil
FWIW -- Tom is not experimenting with my rebuild.... May 26 2010, 02:58 PM
in the $7,500 rebuild closed estimate.
You c... May 26 2010, 05:49 PM
GTeener
You ... May 26 2010, 06:24 PM
[quote name='SirAndy' post='1324119' date='May 26... May 26 2010, 07:46 PM
brp986s
What shop would do all that work for $500?
... May 26 2010, 09:05 PM
What shop would do all that work for $500?... May 27 2010, 02:02 AM
GTeener
What shop would do all that work for $500... May 27 2010, 07:12 AM
davidj
All you need is someone with tools and some spare... May 27 2010, 09:52 AM
Dr Evil Yup. You can modify any WUR to work if necessary, ... May 26 2010, 02:56 PM
SLITS
Yup. You can modify any WUR to work if necessary,... May 26 2010, 03:17 PM
GTeener
Yup. You can modify any WUR to work if necessary... May 26 2010, 06:22 PM
SLITS
[quote name='SLITS' post='1324060' date='May 26 2... May 26 2010, 06:27 PM
GTeener :idea: Wonder if an admin type should break up th... May 26 2010, 06:35 PM
campbellcj Sorry if I missed something in this unfolding saga... May 27 2010, 10:24 AM
GTeener
Sorry if I missed something in this unfolding sag... May 28 2010, 07:32 AM
GTeener itemized parts & work list arrived in the mail... Jun 1 2010, 06:35 PM
Justinp71 Ah so it appears the mfi pump failed and dumped to... Jun 1 2010, 06:54 PM
ArtechnikA
Ah so it appears the mfi pump failed and dumped t... Jun 1 2010, 07:01 PM
Root_Werks Years back I did a 914-6 with 2.2 MFI 'E' ... Jun 2 2010, 09:42 AM
GTeener
Years back I did a 914-6 with 2.2 MFI 'E... Jun 2 2010, 02:55 PM
SLITS
Years back I did a 914-6 with 2.2 MFI 'E... Jun 2 2010, 04:24 PM
ArtechnikA
There is a solenoid on top of the fuel filter con... Jun 2 2010, 05:57 PM
Root_Werks
Years back I did a 914-6 with 2.2 MFI 'E... Jun 3 2010, 08:51 AM
ArtechnikA
My 2.2E had the little air cleaner squirters, but... Jun 3 2010, 09:04 AM
Root_Werks That's really good info guys thanks, kinda off... Jun 3 2010, 09:53 AM
SLITS
That's really good info guys thanks, kinda of... Jun 3 2010, 10:32 AM
GTeener FWIW- Tom Amon also is of the opinion that he no l... Jun 4 2010, 12:12 PM
GTeener Supposedly my engine is back from the machine shop... Jul 1 2010, 02:54 PM
RobW
Supposedly my engine is back from the machine sho... Jul 1 2010, 03:25 PM
jt914-6 :popcorn: Jul 1 2010, 02:57 PM
GTeener Please someone :poke: buy the white 914 that came ... Jul 1 2010, 05:20 PM
GTeener :idea: not too exciting looking. Much cleaner ... Jul 1 2010, 08:07 PM
ArtechnikA Take good notes.
I think you'll be back in the... Jul 2 2010, 06:25 AM
GTeener
Take good notes.
I think you'll be back in th... Jul 2 2010, 01:35 PM
koozy
Take good notes.
I think you'll be back in t... Jul 2 2010, 02:33 PM
ArtechnikA
Take good notes.
I think you'll be back in t... Jul 2 2010, 02:52 PM
RobW
[quote name='GTeener' post='1338317' date='Jul 2 ... Jul 6 2010, 11:36 AM
GTeener :type: Jul 2 2010, 01:03 PM
GTeener :type: Jul 2 2010, 01:05 PM
GTeener :type: Jul 2 2010, 01:06 PM
GTeener :type: Jul 2 2010, 01:23 PM
GTeener :type: Jul 2 2010, 01:26 PM
GTeener :type: Jul 2 2010, 01:27 PM
GTeener This piece looks chipped.
Will it cause a problem... Jul 2 2010, 01:34 PM
RobW :woohoo: :drooley: Jul 2 2010, 01:54 PM
J P Stein I agree with Rich.
It is certainally worth the add... Jul 3 2010, 08:16 AM
koozy You bet. It would be imperative to get everything ... Jul 3 2010, 09:38 AM
GTeener I will verify the ultrasonic cleaning. Jul 6 2010, 11:12 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 12:43 PM |
