| smontanaro |
May 2 2010, 01:42 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,190 Joined: 3-June 05 From: Evanston, IL Member No.: 4,197 Region Association: Upper MidWest |
Went to change the oil on my /6 today. Pulled the drain plug, removed the oil filter and let it drain for awhile. Cleaned the drain plug, installed with a new washer, installed and new oil filter and started filling.
At about the six quart mark the oil filler started to overflow. I've obviously missed something, but what? Thx, Skip |
| sixerdon |
May 2 2010, 01:46 PM
Member ![]() ![]() Group: Members Posts: 466 Joined: 23-May 03 From: Dartmouth, MA Member No.: 731 |
Did you drain the oil tank??
Don |
| smontanaro |
May 2 2010, 02:15 PM
No, how do I do that? (We moved in the past six months or so and I still haven't found my 914/911 books, so I have no ready reference.)
S |
| Ferg |
May 2 2010, 02:33 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,948 Joined: 8-January 03 From: Boulder CO Member No.: 116 Region Association: None
You will have to break the oil line from the engine cooler, unless you have a different drain setup.
| TROJANMAN |
May 2 2010, 02:46 PM
Looks nice in pictures......... ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,275 Joined: 5-March 04 From: Colorado Member No.: 1,753 Region Association: None |
Is it a stock 6, with a stock oil tank?
| SirAndy |
May 2 2010, 02:48 PM
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,469 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
You will have to break the oil line from the engine cooler, unless you have a different drain setup. (IMG:style_emoticons/default/agree.gif) You need to undo one side of the line going from the bottom of the tank to the engine ... (IMG:style_emoticons/default/shades.gif) Andy |
| Ferg |
May 2 2010, 02:54 PM
Start over if it were me, I'm kinda surprised you got six to go in? I'd check the breather line.
| smontanaro |
May 2 2010, 03:46 PM
Stock six, stock tank.
Thanks for the assistance. I guess I will revisit this project next weekend... |
| ArtechnikA |
May 2 2010, 03:57 PM
rich herzog ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,390 Joined: 4-April 03 From: Salted Roads, PA Member No.: 513 Region Association: None |
There's a proper set of offset (and BIG) open-end wrenches for this job. When I was doing it, the factory was the only source (P-numbered tools) and bloody expensive. IIRC, i taped the jaws of some water-pump pilers (Channellocks..) for the 'big' and stationary end, and used some kind of adjustable wrench on the 'movable' end.
Use care if you're doing this in your driveway because 1) the oil will drain from a 30mm hose at an ASTONISHING (i.e. FIREHOSE) rate and 2) there isn't much clearance and you stand an excellent chance of scraping your knuckles when the fitting finally gives way (I still have the scars...). |
| smontanaro |
May 2 2010, 05:04 PM
I'm wondering... Do I need to drain what's there now so it doesn't come out some breather tube in the next week or is the bottom end just going to be bathed in a lot of oil for a few days?
S |
| ClayPerrine |
May 2 2010, 05:10 PM
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,542 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille
Yes, start over.
Pull the drain plug from the sump and drain all the oil from there. Then break the suction oil line in the middle. The factory provided a fitting that is in a bracket just in front of the left rear wheel. Have a big pan for this. Once it has drained, reconnect the line and put the plug back in the sump. Make sure you use a new crush washer on the sump plug. Now fill the tank with 9.5 quarts of oil. Start the engine and warm it up. Then check the oil level with the engine warm and idling. |
| PeeGreen 914 |
May 2 2010, 05:23 PM
Just when you think you're done...wait, there is more..lol ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,219 Joined: 21-September 06 From: Seattle, WA... actually Everett Member No.: 6,884 Region Association: Pacific Northwest
If you don't have these get them. They are a big help (IMG:style_emoticons/default/smile.gif)
http://www.vertexauto.com/ShowItem/4063%20...20-%20Tool.aspx |
| jfort |
May 2 2010, 06:04 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,188 Joined: 5-May 03 From: Findlay, OH Member No.: 652 Region Association: Upper MidWest
Thanks, Phoenix, for the link to the oil line wrenches. Just ordered a set.
Changed oil about 2 weeks ago and had to use pipe wrenches, which don't fit very well. |
| smontanaro |
May 2 2010, 06:07 PM
I don't understand what's so special about the P242 wrench set. Can't appropriately sized open end wrenches do the job?
S |
| ArtechnikA |
May 2 2010, 07:09 PM
I don't understand what's so special about the P242 wrench set. Can't appropriately sized open end wrenches do the job? Yes - but the 'special' tools have the ends indexed just right. There isn't a lot of room to work under there with open-ends that give you just 6 indices. They're a lot nicer - not necessary, but a lot nicer. |
| Eric_Shea |
May 2 2010, 08:11 PM
PMB Performance ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 19,304 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
QUOTE Can't appropriately sized open end wrenches do the job? Do you have proper sized open end wrenches? Most don't. When you price the proper wrenches these are a bargin. And... you need them. You can probably get the two you need here: http://www.samstagsales.com/ |
| SLITS |
May 2 2010, 09:49 PM
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
Harbor freight ... air conditioning wrench set will have ALL the sizes you need ... Metric too!
| Dr Evil |
May 2 2010, 10:35 PM
Send me your transmission! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,041 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region
Clay mentioned a VERY important point. Only put in 9.5 qts. No matter what the dipstick says. I learned this the hard way. You fill to the level while it is warmed up and running, otherwise it pisses oil everywhere (IMG:style_emoticons/default/dry.gif)
| PeeGreen 914 |
May 2 2010, 11:05 PM
Clay mentioned a VERY important point. Only put in 9.5 qts. No matter what the dipstick says. I learned this the hard way. You fill to the level while it is warmed up and running, otherwise it pisses oil everywhere (IMG:style_emoticons/default/dry.gif) Not all tanks are the same (IMG:style_emoticons/default/poke.gif) Then there are those with oil lines that are longer and then those that have coolers. But yes, if you over fill it makes a BIG mess (IMG:style_emoticons/default/huh.gif) |
| Dr Evil |
May 2 2010, 11:09 PM
The point is, if you fill it to the full mark while it is cold, when you start it it will piss oil through the vent into your intake. (IMG:style_emoticons/default/wink.gif)
Lo-Fi Version | Time is now: 2nd April 2026 - 05:58 PM |
