| smontanaro |
May 2 2010, 01:42 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,190 Joined: 3-June 05 From: Evanston, IL Member No.: 4,197 Region Association: Upper MidWest |
Went to change the oil on my /6 today. Pulled the drain plug, removed the oil filter and let it drain for awhile. Cleaned the drain plug, installed with a new washer, installed and new oil filter and started filling.
At about the six quart mark the oil filler started to overflow. I've obviously missed something, but what? Thx, Skip |
smontanaro Six oil change - I know I missed something... May 2 2010, 01:42 PM
sixerdon Did you drain the oil tank??
Don May 2 2010, 01:46 PM
smontanaro No, how do I do that? (We moved in the past six m... May 2 2010, 02:15 PM
Ferg You will have to break the oil line from the engin... May 2 2010, 02:33 PM
You will have to break the oil line from the engi... May 2 2010, 02:48 PM
TROJANMAN Is it a stock 6, with a stock oil tank? May 2 2010, 02:46 PM
Ferg Start over if it were me, I'm kinda surprised ... May 2 2010, 02:54 PM
smontanaro Stock six, stock tank.
Thanks for the assistance.... May 2 2010, 03:46 PM
ArtechnikA There's a proper set of offset (and BIG) open-... May 2 2010, 03:57 PM
smontanaro I'm wondering... Do I need to drain what... May 2 2010, 05:04 PM
ClayPerrine Yes, start over.
Pull the drain plug from the su... May 2 2010, 05:10 PM
Phoenix 914-6GT If you don't have these get them. They are a b... May 2 2010, 05:23 PM
jfort Thanks, Phoenix, for the link to the oil line wren... May 2 2010, 06:04 PM
smontanaro I don't understand what's so special about... May 2 2010, 06:07 PM
ArtechnikA
I don't understand what's so special abou... May 2 2010, 07:09 PM
Eric_Shea
Do you have proper sized open end wrenches? Mos... May 2 2010, 08:11 PM
SLITS Harbor freight ... air conditioning wrench set wil... May 2 2010, 09:49 PM
Dr Evil Clay mentioned a VERY important point. Only put in... May 2 2010, 10:35 PM
Phoenix 914-6GT
Clay mentioned a VERY important point. Only put i... May 2 2010, 11:05 PM
Dr Evil The point is, if you fill it to the full mark whil... May 2 2010, 11:09 PM
jt914-6 This is what I've done. Although not using the... May 3 2010, 04:43 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 08:49 AM |
