Check out these parts!
1970-76 914 Used Voltage Regulator
http://cgi.ebay.com/ebaymotors/1970-76-Por...=item5ad915e28e1970-76 914 used clutch cable and bracket
http://cgi.ebay.com/ebaymotors/1970-76-Por...=item335ca035291970-76 914 used pair of rear stub axles
http://cgi.ebay.com/ebaymotors/1970-76-Por...=item335ca036ea1970-76 914 used engine lid hinges
http://cgi.ebay.com/ebaymotors/1970-76-Por...=item335ca03a511970-76 914 used wiper linkage assembly
http://cgi.ebay.com/ebaymotors/1970-1976-P...=item5ad915ec8b1970-76 914 used rubber strips, weather seals
http://cgi.ebay.com/ebaymotors/1970-1976-P...=item335ca4b7681970-76 914 used engine lid grill
http://cgi.ebay.com/ebaymotors/1970-1976-P...=item335ca4c060914 911 912 collection of 'rubber bits'
http://cgi.ebay.com/ebaymotors/Porsche-911...=item5ad91ccbab914 911 912 Axle bolts, washers, straps
http://cgi.ebay.com/ebaymotors/Porsche-911...=item335ca83e37914 used plastic cover voltage regulator & ignition
http://cgi.ebay.com/ebaymotors/Porsche-914...=item335ca8436c1970-76 914 used pair of horns
http://cgi.ebay.com/ebaymotors/1970-1976-P...=item335ca84add1970-76 914 used headlight pivot point and arm
http://cgi.ebay.com/ebaymotors/1970-1976-P...=item5ad91ce5491975 914 used 1.8 Distributor JFU 4
http://cgi.ebay.com/ebaymotors/1975-Porsch...=item5ad91cee7a1970-76 914 used W/S Washer pressurized tank
http://cgi.ebay.com/ebaymotors/1970-1976-P...=item335ca8618b1970-76 914 used pair of rear suspension mounts
http://cgi.ebay.com/ebaymotors/1970-76-Por...=item5ad91cf97a1970-76 914 used horn pad
http://cgi.ebay.com/ebaymotors/1970-76-Por...=item5ad91d010d914, 912, 911 10+ pounds of hardware, clamps, straps
http://cgi.ebay.com/ebaymotors/Porsche-911...=item5ad91d16d0914, 912, 911 31+ pounds nuts, bolts, Etc.
http://cgi.ebay.com/ebaymotors/Porsche-911...=item5ad91d22391970-76 914 used Clutch Arm/Clutch Fork
http://cgi.ebay.com/ebaymotors/1970-76-Por...=item5ad921c700
