SBC V8 Water Pump Failure, 3 Styles of Pumps Tested BYPASS THERMOSTAT UPDATE |
nick mironov |
May 6 2010, 12:32 PM
nickm Group: Members Posts: 204 Joined: 12-June 05 From: San Francisco, CA Member No.: 4,264 |
My Renegade water pump failed yesterday. The pump impeller is stamped steel and the blades all just folded over or sheared off. I understand that the cast impellers are much stronger, but that not all manufacturer's cast models will fit into the Renegade housing. Anybody have experience with cast impeller pumps that will fit into the Renegade housing?
Since there is no bypass in the Renegade system, Renegade instructions are to limit the motor RPM to 3,000, or less, untill the thermostat opens. I have observed this, but the pump still failed after 5,500 miles. Renegade now makes a bypass kit, which I going to try, but I would still like to get a more durable pump. Nick |
nick mironov |
May 6 2010, 11:56 PM
That failure looks exactly like mine...
The thread that was referenced in the previous reply was the thread that I found and it was informative. However, that thread does not have specifics on which manufacturer/model of a cast impeller pump will fit. It appears that Drive-Ability had to alter the housing to get his unidentified cast impeller pump to fit into the housing. There are lots of cast impeller pumps to be found on the web, but which ones actually fit? Nick |
Lo-Fi Version | Time is now: 20th May 2024 - 04:43 AM |
