SBC V8 Water Pump Failure, 3 Styles of Pumps Tested BYPASS THERMOSTAT UPDATE |
nick mironov |
May 6 2010, 12:32 PM
nickm Group: Members Posts: 204 Joined: 12-June 05 From: San Francisco, CA Member No.: 4,264 |
My Renegade water pump failed yesterday. The pump impeller is stamped steel and the blades all just folded over or sheared off. I understand that the cast impellers are much stronger, but that not all manufacturer's cast models will fit into the Renegade housing. Anybody have experience with cast impeller pumps that will fit into the Renegade housing?
Since there is no bypass in the Renegade system, Renegade instructions are to limit the motor RPM to 3,000, or less, untill the thermostat opens. I have observed this, but the pump still failed after 5,500 miles. Renegade now makes a bypass kit, which I going to try, but I would still like to get a more durable pump. Nick |
SLITS |
May 7 2010, 07:08 AM
"This Utah shit is HARSH!" Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
In the other thread, someone asked what Ford did to prevent cavitation on their race engines. Ford redesigned the impeller to be a six curved blade, smaller diameter cast iron unit. They sold it for years in the Motorsports Division as a high performance impeller (to prevent cavitation at high rpms). Ford stopped making them so our GM had them cast and machined.
Like I said before, the minimum number of units is 300. So far that would leave us with 297 in stock if we did the Mopar units. (IMG:style_emoticons/default/sad.gif) |
Lo-Fi Version | Time is now: 20th May 2024 - 04:28 AM |
