Looking for a trick to remove the crank spacer sleeve |
root |
May 8 2010, 11:19 AM
Two Wheeled Type4 Completed! Group: Members Posts: 849 Joined: 5-May 04 From: Sterling, VA Member No.: 2,026 Region Association: None |
I always used to leave the spacer in the crank and just have the machine shop clean the hole out during polishing. This time I have my own setup to checkout main journal runout but the spacer sleeve with it's slot seem to interfere with dead centering on the lathe chuck. Anybody have a good method to remove this sleeve so I can get an accurate runout? (IMG:style_emoticons/default/confused24.gif) |
Lo-Fi Version | Time is now: 18th May 2024 - 02:30 AM |
