OT - Prodex insulation, Keeping the Garage Cool |
VegasRacer |
May 8 2010, 12:13 PM
ELVIRA Group: Benefactors Posts: 8,509 Joined: 27-March 03 From: Between Scylla and Charybdis Member No.: 481 Region Association: None |
Anbody ever use this stuff? Prodex insulation (IMG:style_emoticons/default/smash.gif) Does it work?
Mike Bellis |
May 8 2010, 12:42 PM
It has an R value of 15.67 with a single layer. I think it would work great. Most house walls have an R value of 6. It will not eliminate all the heat in your garage but it should cut it down.
May 8 2010, 12:56 PM
Resident German Group: Admin Posts: 41,641 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
It would work even better if it was on the outside.
The metal surface is designed to reflect most of the radiant energy. (IMG:style_emoticons/default/popcorn[1].gif) Andy |
Lo-Fi Version | Time is now: 17th May 2024 - 06:57 PM |
