How to set initial timing for new engine |
Cevan |
May 10 2010, 10:47 AM
Senior Member Group: Members Posts: 1,079 Joined: 11-December 06 From: Western Massachusetts Member No.: 7,351 |
I am about to fire up my engine for the first time after rebuilding it. I'm using an L-Jet distributor with no vacuum advance or retard. I'm using carbs.
I'm trying to determine where I should set the dizzy. From what I could gather off the internet, the total mechanical advance for this dizzy at 3600 rpms is 21-25 degrees (I'll average it to 23 degrees). I think 28 degrees total advance is what is recommended as a starting point so am I correct in setting the static timing to 5 degrees BTDC? |
SLITS |
May 10 2010, 10:53 AM
That'll work.
McMark |
May 10 2010, 10:57 AM
Funny how these things come in pairs... read this thread.
(IMG:style_emoticons/default/agree.gif) 5 BTDC should be fine. There is also a little line in the distributor edge that shows you where the rotor should point. |
Cevan |
May 10 2010, 11:07 AM
While I did my deck height measurements, I had installed the fan shroud and marked my fan at exact TDC. My fan is from an L-Jet car and only had a mark at 7.5 BTDC. So I will go with 5 degrees BTDC. Wish me luck!
Lo-Fi Version | Time is now: 17th May 2024 - 06:54 PM |
