OT - Lawnmower help |
rtalich |
May 10 2010, 02:12 PM
Member Group: Members Posts: 279 Joined: 25-September 06 From: Bellevue, WA Member No.: 6,913 Region Association: None |
Tried mowing the lawn this weekend. It would run for a while and then sort of backfire a bit then die. One pull, starts back up, mow for a bit then dies again. Any ideas of what the problem might be?
Thanks, Rob |
porschecb |
May 10 2010, 02:17 PM
Senior Member Group: Members Posts: 1,092 Joined: 13-August 04 From: Las Vegas NV Member No.: 2,529 Region Association: None |
Air filter? Mine was full of (IMG:style_emoticons/default/stromberg.gif) .
rtalich |
May 10 2010, 02:22 PM
Looks brand new. |
orange914 |
May 10 2010, 02:46 PM
http://5starmediaworks.com/index.html Group: Members Posts: 3,371 Joined: 26-March 05 From: Ceres, California Member No.: 3,818 Region Association: Northern California |
old winter fuel? sounds like it's starving. it's probably got no filter and may have caught a chunk-o-crap inroute to the carb. if you ever run it low, sometimes it'l plug
iamchappy |
May 10 2010, 02:59 PM
clean out float bowl
zymurgist |
May 10 2010, 03:09 PM
"Ace" Mechanic Group: Members Posts: 7,411 Joined: 9-June 05 From: Hagerstown, MD Member No.: 4,238 Region Association: None |
Last year, my mower had a similar problem. I blew carb cleaner and compressed air through the carb passages and it helped. This year, not so much. I rebuilt the carb and now it starts on the first pull (as long as I use the priming bulb before starting).
6freak |
May 10 2010, 03:28 PM
VENT PLUGGED UP ON TOP OF FUEL CAP ??
underthetire |
May 10 2010, 03:38 PM
Cracked priming bulb, plugged carb, old gas. If your lucky once you get that fixed your coil won't go out like mine did. Hopefully not a Tecumseh motor. No parts for them any longer.
rtalich |
May 10 2010, 05:39 PM
Thanks for the suggestions guys!! No priming buld on this mower. Will take the carb apart and clean clean clean... the culprits got to be with the float. Will also check for a plugged fuel cap.
EdwardBlume |
May 10 2010, 05:48 PM
My sears crapsman mower is doing the same thing, and I'm pretty sure its crappy (factory) gas...
Jake Raby |
May 10 2010, 06:29 PM
Water in the fuel... Drain the tank, clean the carb and the problem will go away. betcha.
URY914 |
May 10 2010, 07:14 PM
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,737 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
Check the ground strap between the tranny and the body.
jmill |
May 10 2010, 08:39 PM
I always run the lawn mower and snow blower dry. I'm betting old fuel too. Most carbs have drains on the bottom of the bowl. There will be a spring on a needle type valve. Press up and it'll drain. Drain it out and give new fuel a shot. If that doesn't work unscrew the bowl and clean it out along with the passages.
underthetire |
May 10 2010, 08:41 PM
Check the ground strap between the tranny and the body. Now thats just plain funny (IMG:style_emoticons/default/biggrin.gif) |
rtalich |
May 10 2010, 08:43 PM
Check the ground strap between the tranny and the body. Now thats just plain funny (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/lol-2.gif) (IMG:style_emoticons/default/agree.gif) |
charliew |
May 10 2010, 09:47 PM
My mower runs better than my 914 and turns a whole lot sharper. It's like riding a cutting horse.
zymurgist |
May 11 2010, 04:22 AM
@Charlie: Zero turn?
My main mower is a 1970 John Deere 140 with Kohler K321 engine. I can't keep a head gasket on it... seriously thinking of repowering it with a Briggs @ Stratton 18 HP V-Twin. |
EdwardBlume |
May 11 2010, 07:16 AM
VaccaRabite |
May 11 2010, 07:33 AM
En Garde! Group: Admin Posts: 13,445 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
zymurgist |
May 11 2010, 08:14 AM
@Charlie: Zero turn? My main mower is a 1970 John Deere 140 with Kohler K321 engine. I can't keep a head gasket on it... seriously thinking of repowering it with a Briggs @ Stratton 18 HP V-Twin. How long do you think it will be up on jack stands? Ha! My '84 JD 111 sat for a couple of years in the driveway, partially disassembled, before I finally sold it on Craigslist. This one's a keeper so I will probably want to wait until summer, when I won't have to mow as much. For now I've got a stack of head gaskets and probably a spare head. |
Lo-Fi Version | Time is now: 21st May 2024 - 08:45 PM |
