| Rand |
May 13 2010, 08:19 AM
Cross Member ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,413 Joined: 8-February 05 From: OR Member No.: 3,573 Region Association: None |
Want to run power tools and a light-duty welder - just a 110-powered flux-core. I know there's math to calculate power requirements, but there are also variables about how long you can run it continuously and all that. So I thought I'd see if those with experience would chime in.
I don't need heavy duty. But I don't want to be worried about when I have to stop and let things cool down. Just for argument's sake, let's use Harbor Freight as an example... Say you have this 90-amp welder: http://www.harborfreight.com/90-amp-flux-w...lder-98871.html Out of these generators, which could and could not handle it? http://www.harborfreight.com/engines-gener...generators.html |
| Rand |
May 13 2010, 08:52 AM
So the grinder is going to be a tougher client than the welder? I'll just give the wheel a spin before turning it on. Haha.
I'm not going to run more than one thing at a time. Clearly the $700 unit will handle it. But if the $250 unit is up to the task, that's quite a price difference. Maybe I should shop Sears for something in between. (IMG:style_emoticons/default/smile.gif) |
Rand Generators and power requirements May 13 2010, 08:19 AM
jmill 120 volts x 15 amps = 1800 watts. Those 7000 watt... May 13 2010, 08:23 AM
Rand If it's that simple then the 2200 watt generat... May 13 2010, 08:32 AM
PRS914-6 Rand, it doesn't take a large generator to run... May 13 2010, 08:42 AM
PRS914-6
So the grinder is going to be a tougher client th... May 13 2010, 09:26 AM
Spoke
So the grinder is going to be a tougher client th... May 13 2010, 10:37 AM
underthetire I can tell you first hand that the 90 amp HF flux ... May 13 2010, 09:19 AM
DonTraver Rule #1 with generators.
Calculate continuous loa... May 13 2010, 10:43 AM
underthetire
Caluculate continuous l... May 13 2010, 10:45 AM![]() ![]() |
Lo-Fi Version | Time is now: 11th February 2026 - 09:46 AM |
