Fog light removal, wiring at least |
echocanyons |
Apr 3 2004, 07:09 PM
Advanced Member Group: Benefactors Posts: 2,096 Joined: 24-December 02 From: Bay Area, CA Member No.: 7 Region Association: Central California |
I need to remove the fog lights on my car but I cant seem to figure out how to get the wiring off of the light.
Im sure the lens is removable somehow to change the bulb but I dont understand how to do this any ideas? |
415PB |
Apr 3 2004, 08:42 PM
Member Group: Benefactors Posts: 498 Joined: 7-August 03 From: So Cal Member No.: 996 |
Remove the foglight with bracket, via the large allen bolt. On the bottom of the foglight bezel is a screw. Unsrew this and remove the tab that holds the bezel in place. Remove the bezel and now you will see how the wires are connected. 12V is simply held in by a screw (unscrew this screw) and ground just plugs into a male connector.
echocanyons |
Apr 3 2004, 08:50 PM
I unmounted it and removed the screw but couldnt figure it out how to remove the bezel.
There is a hole in the bottom of the bezel do you push this over to release the bezel? |
415PB |
Apr 3 2004, 10:00 PM
There is supposed to be a small tab that is screwed into that hole. If there isn't one, then you are missing yours. Gently pry the bezel from the lamp housing and and look inside. Hope this helps.
echocanyons |
Apr 3 2004, 11:11 PM
I removed the tab but it didnt budge maybe it was stuck on with grime and time.
Ill give it another shot tomorrow Thanks! |
echocanyons |
Apr 4 2004, 05:22 PM
got the housings apart they were just stuck by grime.
I had to cut the wiring cuz it was soldered to the light. Thanks for the tips (IMG:style_emoticons/default/smilie_pokal.gif) |
Lo-Fi Version | Time is now: 20th September 2024 - 07:05 PM |
