| bradtho |
May 16 2010, 09:35 PM
Member ![]() ![]() Group: Members Posts: 266 Joined: 22-December 09 From: Seattle, WA Member No.: 11,165 Region Association: None |
Using a drill I figured out that the speedo cable was broken, so I bought another and broke it testing it with my drill. I cut one of the tips off and pulled the speedometer completely out. Using the tip and a vise grip, I am unable to turn the speedo at all. I followed the instructions on PP to disassemble the speedo and can actually spin the magnet wheel, but it will not spin the square drive for the cable when the magnet spins.
btw: the needle moves quite freely, and the speed unit is completely disconnected from the odo so it can't be the odometer gears. Reading other threads it sounds like taking this apart any further isn't advised. Anyone had this problem before or have a suggestion besides sending it somewhere for repair? |
| McMark |
May 17 2010, 12:33 PM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,180 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None |
Buy a different one. They're not expensive. One of the guys up in your area probably has one.
| SirAndy |
May 17 2010, 01:08 PM
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,369 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Buy a different one. They're not expensive. One of the guys up in your area probably has one. (IMG:style_emoticons/default/agree.gif) |
| messix |
May 17 2010, 01:19 PM
AKA "CLUTCH KILLER"! ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,995 Joined: 14-April 05 From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada Member No.: 3,931 Region Association: Pacific Northwest |
look in the classifieds, rich has a parts posting for $9.14 parts. rdauenhauer http://www.914world.com/bbs2/index.php?sho...88677&st=20
| markb |
914less :( ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,450 Joined: 22-January 03 From: Nipomo, CA Member No.: 180 Region Association: Central California
I'd sell you a used (untested) one for $25.00 shipped.
| Bartlett 914 |
May 17 2010, 01:29 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,218 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest |
Using a drill I figured out that the speedo cable was broken, so I bought another and broke it testing it with my drill. I cut one of the tips off and pulled the speedometer completely out. Using the tip and a vise grip, I am unable to turn the speedo at all. I followed the instructions on PP to disassemble the speedo and can actually spin the magnet wheel, but it will not spin the square drive for the cable when the magnet spins. btw: the needle moves quite freely, and the speed unit is completely disconnected from the odo so it can't be the odometer gears. Reading other threads it sounds like taking this apart any further isn't advised. Anyone had this problem before or have a suggestion besides sending it somewhere for repair? I went through several speedo cables before I realized the problem was the trip odometer. It would reach 99 miles and when turning 100 the cable would break. |
| charliew |
May 17 2010, 07:39 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,363 Joined: 31-July 07 From: Crawford, TX. Member No.: 7,958 |
It's not rocket science. Put the cable or a small screwdriver in the square hole and try to turn it. There is no mechanical between the magnet and the cup wheel that the needles is connected to. The needle moves from a magnetic field.Look inbetween the gears for a obstruction that might keep them from turning. try a little 3 in one oil on the shafts. The input goes directly to the magnet if I remember from about 10 years ago with the screw gear turning the number wheels through a gear on the end of the shaft. All mechanical speedos are the same. The 99 rollover is a little tang that comes around and turns the 1000 0 to a one just like all the other 0's. Get another one and then you can take this one apart and be educated. Usually it's worn bushings and the magnet and wheel that rubs. Or the plastic gears loose their mesh. If they get too far apart the tips of the gear teeth bind. I once had a cable that was too long and bound up the speedo. Thats pretty easy as unscrewing the cable housing nut a little will show it to get hard to tighten as it gets fully seated.
| bradtho |
May 17 2010, 08:25 PM
It's not rocket science. Put the cable or a small screwdriver in the square hole and try to turn it. There is no mechanical between the magnet and the cup wheel that the needles is connected to. that's just it, I've completely disconnected the speed unit from all the odometer gears. the square hole will not spin. I can spin the magnet (not easily) but I assume that's just the magnet spinning around the stuck shaft that the square drive spins. |
| underthetire |
May 17 2010, 08:30 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,062 Joined: 7-October 08 From: Brentwood Member No.: 9,623 Region Association: Northern California |
A 25.00 speedo is a lot cheaper than two 38.00 cables. Why fight it. (IMG:style_emoticons/default/confused24.gif)
| charliew |
May 18 2010, 12:57 PM
If you have broken the grip of the magnet to the shaft you might as well go get another one and just play with the one you have. The shaft may have siezed in the bushing but I haven't ever seen that and most of my toys are at least as old as a 914 but they also aren't as open to the elements.
Lo-Fi Version | Time is now: 7th December 2025 - 08:58 AM |
