| crxnug |
May 17 2010, 06:16 PM
Member ![]() ![]() Group: Members Posts: 81 Joined: 20-December 07 From: ontario, canada Member No.: 8,489 |
are there any differences between a 1973 and 74 2.0 engine,? are parts interchangeable, are there differences in the fuel injection? and info would be much appreciated
| McMark |
May 17 2010, 06:20 PM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,180 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None |
Not much. Are you looking for information regarding running a stock motor? Or in terms of a rebuild core?
For a rebuild core, they are the same. |
| Tom_T |
May 17 2010, 06:31 PM
TMI.... ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,321 Joined: 19-March 09 From: Orange, CA Member No.: 10,181 Region Association: Southern California
are there any differences between a 1973 and 74 2.0 engine,? are parts interchangeable, are there differences in the fuel injection? and info would be much appreciated (IMG:style_emoticons/default/agree.gif) Mostly differences at the earlier MPS, CHT, ECU & other EFI components - otherwise they're the same basic GA engine 73 & 74, as McMark said. So you could transplant the appropriate MY's D-jet set-up if you're looking for a new engine/core, but save the old one if it's a matching number original engine to the car! |
| JRust |
May 17 2010, 07:41 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,317 Joined: 10-January 03 From: Albany Oregon Member No.: 129 Region Association: Pacific Northwest
Yeah the same but for the Fuel Injection. You don't want to mix the FI between the years. Also don't mix the wiring between them. Dont ask me how I know (IMG:style_emoticons/default/dry.gif)
| underthetire |
May 17 2010, 07:43 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,062 Joined: 7-October 08 From: Brentwood Member No.: 9,623 Region Association: Northern California |
one year (IMG:style_emoticons/default/piratenanner.gif)
| JeffBowlsby |
May 17 2010, 08:12 PM
914 Wiring Harnesses & Beekeeper ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,247 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None
Then '74 is by far the better engine...:tongue in cheek:
Actually there are few subtle and meaningless differences: The 74 has: 1 year less wear... Single port throttle body, no throttle shaft spring Charcoal canister relocated to the engine bay (@ mid-year 74) Some, not all, FI components were changed for the 74 model as mentioned above Thaz all... |
| detoxcowboy |
May 17 2010, 08:54 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,294 Joined: 30-January 08 Member No.: 8,642 Region Association: Africa |
are there any differences between a 1973 and 74 2.0 engine,? are parts interchangeable, are there differences in the fuel injection? and info would be much appreciated For a more detailed of what changed and what is inter changeable and what is preferd.. link below http://members.rennlist.com/pbanders/DJetParts.htm The main thing is if your using the 037 ecu from '73 then you must use the corresponding cht w/ resistor and mps.. that really is the only major rule.. change the ecu to 74-76 and the fi components are alot more flexible.. 74 stock is a good bet as then you can go alot of ways when in need for a part. anything more than that will just confuse your question.. read that link it will be your best guide.. |
Lo-Fi Version | Time is now: 2nd May 2026 - 11:20 AM |
