Paint Cut and Buff Prodeure Basics? |
detoxcowboy |
May 18 2010, 10:08 PM
Senior Member Group: Members Posts: 1,294 Joined: 30-January 08 Member No.: 8,642 Region Association: Africa |
I am getting my car painted in the next 3 weeks, and am wanting to save $400 but cutting and buffing their base coat clear coat myself. How difficult is the procedure and where can I get a cheap buffer that would be for this kind of job?
76-914 |
May 18 2010, 10:42 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,501 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
I am getting my car painted in the next 3 weeks, and am wanting to save $400 but cutting and buffing their base coat clear coat myself. How difficult is the procedure and where can I get a cheap buffer that would be for this kind of job? A decent import buffer will run ya 125 + pads. It would last the average Joe a lifetime. Harbor F has a pnuematic DA for wet sanding that is less than 35. You have to shake it to start it sometimes. (IMG:style_emoticons/default/lol-2.gif) Figure another 40 for good wet/dry sanding discs if you by it online. 200 if you buy 4 disc pac's at Home Depot. Another 50 for 2 bottles(different grits) of polishing compounds. Different brands at different paint stores. How much did you say you could save. The 400 isw worth it. But then again if you enjoy the task, it is an experience. |
effutuo101 |
May 18 2010, 10:52 PM
Advanced Member Group: Members Posts: 2,734 Joined: 10-April 05 From: Lemon Grove Member No.: 3,914 Region Association: Southern California |
(IMG:style_emoticons/default/agree.gif) if they are only charging 400 do cut and buff, take it. If they screw up the paint (burn it or cut through) they get to fix it. I got quoted over $1k to color cut and buff my car. The paint doesn't have much orange peel to it.
If you are going to do it, 2000 grit sand paper, lots of water and a small amount of soap. Act like you are just guiding the sand paper, not trying to take off paint. Very light touch. you can always go back and do it again. Then go with a medium cut cleaner and work your way to fine cut cleaners to remove the rest of the scuff from the 2k grit. |
detoxcowboy |
May 18 2010, 10:59 PM
nice, saved me some sweat..
charliew |
May 19 2010, 09:51 AM
You will burn through it if you've never done it before. If I were telling someone how to do it I would say do it all by hand so you don't go too far. Most people can't sand or buff by hand very long as those muscles aren't use to that type of work. When you use a machine it's real easy to go to far on the edges. You also need to pay attention to the direction of the wheel and keep it going off the edge not into it. I like air buffers. I also start with 1000 then 1200 or 1500 then 2000 grit and lots of water and real good light all by hand. Also the trick is to not end up with super smooth in one place and orange peel in another or a little orange peel to hide a imperfection in the body and therefore a little op overall. The smoother it gets the more the waves come out.
detoxcowboy |
May 19 2010, 10:19 AM
You will burn through it if you've never done it before. If I were telling someone how to do it I would say do it all by hand so you don't go too far. Most people can't sand or buff by hand very long as those muscles aren't use to that type of work. When you use a machine it's real easy to go to far on the edges. You also need to pay attention to the direction of the wheel and keep it going off the edge not into it. I like air buffers. I also start with 1000 then 1200 or 1500 then 2000 grit and lots of water and real good light all by hand. Also the trick is to not end up with super smooth in one place and orange peel in another or a little orange peel to hide a imperfection in the body and therefore a little op overall. The smoother it gets the more the waves come out. Charlie I appreciate that, I was thinking by hand when I asked. that is just the kind of laborouisness (IMG:style_emoticons/default/confused24.gif) I have done n some way or another in my life.. I just wanted to get a good paint job that I would not have to worry or cry if say my friends 4 year old bangs on it with a toy or other more careless adults in parking lots,, baring any total catastrophe I can see me getting paint every 4 years or so.. or even given the environment painting it myself.. It is not rocket science, it is a learnable skill.. |
IronHillRestorations |
May 19 2010, 11:06 AM
Have the shop do it, you'll save yourself some grief. Practice on an old car you don't care much about.
effutuo101 |
May 19 2010, 01:03 PM
Blood sweat and tears. Plan on about a half hour to hour on each fender for each step. Your results will vary on each piece as you get tired. If you calculate out 20 bucks an hour for each panel with 10 panels to work (4 fenders, 2 doors, front hood, back hood, engine cover, and between the tail lights) on and minimum of 2 hours per panel (3 hours most likely for the larger pieces), Plus the hardware to do the work ($80-$400) that would be 800 -1200 total cost including hardware and sand paper. $400 and a guarantee is a steal. If you are not happy, they get to do it again. (IMG:style_emoticons/default/smile.gif) |
Speedster Mike |
May 19 2010, 01:08 PM
Speedster Mike Group: Members Posts: 39 Joined: 1-March 09 From: Louisville , Ky. Member No.: 10,113 Region Association: Upper MidWest |
If you have never done it ...DON'T DO IT! This is not the one to learn on! Let the pro do it!....You'll be glad you did! If the pro screws up ....He's responsible
TheCabinetmaker |
May 19 2010, 01:11 PM
Don't do it!!!!!!!!! Its an art that takes a lot of practice, and a light touch. Let the pros do it. You don't want to ruin your new paint job do you?
underthetire |
May 19 2010, 03:15 PM
My first one was a Datsun pickup I painted in High school. Even at 17 it was tiring work, did it all by hand, even the buffing. Just did my crappy old paint on my 914, sanding then using the HF buffer i bough for 29.00. The thing actually worked very well. Point is, you can learn to do it, but do you really want to? If you do, you can come practice on my car some. (IMG:style_emoticons/default/biggrin.gif)
scotty b |
May 19 2010, 07:45 PM
If I could trust someone to do it properly for $400.00 I'd pay them myself and not be in constant pain (IMG:style_emoticons/default/lol-2.gif)
detoxcowboy |
May 19 2010, 07:53 PM
detoxcowboy |
May 19 2010, 08:07 PM
Don't do it!!!!!!!!! Its an art that takes a lot of practice, and a light touch. Let the pros do it. You don't want to ruin your new paint job do you? Your right , I do not want to wreck my new paint job. I am even priming and sanding it myself before I bring it in, also have the entire car apart again, glass,engine out gas tank out, interior out dash off, carpets gone, doors are emptied ect.. I really just want them to spray and bake it, but your right I whish I could just roll into a trusted painter whom has taken 914 's apart and put them back together, paints beatifully ect., I know there is at least some out there but they want $4,000-$10,000 for me at least if I pay that much then I am not going to enjoy driving it in Montana mud snow blizzrd icy gravel ect.. and the paint damage happens anywhere, I just think paying more for paint than orignal purchase price is touchy. I paid $8500 for my 914 and have twice that into it mostly new parts, damn all new parts.. So if I can't afford that kind of Pro, whihc is a true pro then you get the shops of whom you can get a decent paint job but how much do you want to pay for decent.. possible crap shoot.. I understand pros' I live in so. cal. and they have an pro up front doing all the selling and a handfull of _________ doing all the work. And along those lines then I would never work on my car because the pro's blah blah $120/hr.. Sure I was nervous when I first did cylinder heads and pistons ect. , but the money I save on not going to mechanincs allow me to buy more New/Nos and leather ect.. for the car.. But it is all good and I appreciate any and all input there is no wrong really./. |
thomasotten |
May 20 2010, 07:26 AM
Senior Member Group: Members Posts: 1,544 Joined: 16-November 03 From: San Antonio, Texas Member No.: 1,349 |
I am getting my car painted in the next 3 weeks, and am wanting to save $400 but cutting and buffing their base coat clear coat myself. How difficult is the procedure and where can I get a cheap buffer that would be for this kind of job? A decent import buffer will run ya 125 + pads. It would last the average Joe a lifetime. Harbor F has a pnuematic DA for wet sanding that is less than 35. You have to shake it to start it sometimes. (IMG:style_emoticons/default/lol-2.gif) Figure another 40 for good wet/dry sanding discs if you by it online. 200 if you buy 4 disc pac's at Home Depot. Another 50 for 2 bottles(different grits) of polishing compounds. Different brands at different paint stores. How much did you say you could save. The 400 isw worth it. But then again if you enjoy the task, it is an experience. Do NOT use a DA sander to cut and buff! Use a sanding block. You want to make the surface flat. DA sanders are for material removal. |
Rav914 |
May 20 2010, 08:40 AM
All-weather fan Group: Members Posts: 738 Joined: 15-April 07 From: WA Member No.: 7,669 Region Association: None |
Even the pros started somewhere. The more you do it the better you get at it.
Look at what Thomas accomplished. Just sayin'..... |
detoxcowboy |
May 20 2010, 08:41 AM
Thank YOu everybody!! I think I got a great picture of what to expect.. now do I have the balls to do it? Maybe $400 does not sound that bad.. Sure would like to learn someday someway though..
KELTY360 |
May 20 2010, 11:31 AM
914 Neferati Group: Members Posts: 5,031 Joined: 31-December 05 From: Pt. Townsend, WA Member No.: 5,344 Region Association: Pacific Northwest |
I say go for it cowboy! What's the worst that can happen; you mess up a spot on the new paint? You're going to do that anyway once you get to Montana. The biggest danger is that you do it perfect and then can't bring yourself to drive it for fear of hurting it. If someone else does the work you won't have the psychic investment to worry about. It's all very zen. (IMG:style_emoticons/default/driving.gif)
charliew |
May 20 2010, 12:11 PM
I'm not sure what you will do if you screw it up. You won't like the cost to fix the mess up. I never came across someone that wanted to risk a new paint job learning how to sand and buff it out. If it's for sure not going to be taken good care of why even buff it out? Good luck
6freak |
May 20 2010, 12:34 PM
I am getting my car painted in the next 3 weeks, and am wanting to save $400 but cutting and buffing their base coat clear coat myself. How difficult is the procedure and where can I get a cheap buffer that would be for this kind of job? and not have the pro`s do it (IMG:style_emoticons/default/slap.gif) .....big mistake! but hey its your money |
Lo-Fi Version | Time is now: 15th May 2024 - 01:40 PM |
