FS: Misc Parts, Super Cheap |
dlee6204 |
May 25 2010, 11:06 AM
$15
• J sail trim pieces (painted) (both) • Inside Door Handles and trim (both sides) • • Early Model Jack • Turn Signal Bucket w/ bracket • • 1.7L Distributor from Carb motor ( I can get part number if needed) • 1.7L Fan with all fins intact $10 • Headlights (each) • • Wiper Arms (per set, 2 sets) • Vertical Sail seal channel trim (both) • Rear View Mirror • Side Marker Light • Silver Button Tach (2) • Silver Button Gas Gauge (2) • Silver Button Speedo $5 • • Headlight motors (each) • Rubber Shift Boot • Door latches (each) • Horn • Plastic headlight mechanism covers (2) • Female Seatbelts • Retractable Seatbelts (each, poor shape) • Driver side sun visor • Side Bolsters (each) • Engine Lid latch • Rubber Shock tower caps (both) • Oil Filter Mount 1.7L (may fit other engines) • 1.7L Oil Cooler Shroud w/ gasket (may fit other engines • Later style Vent $2 • Round headlight motor piece • Oil Cap • Drain Funnel • • Hazard switch pull • Side marker light base • Dog Bone • Pedal Pads (price per all 3) • • Misc Headlight Hardware • Misc Seatbelt Hardware • Amco Shift Knob (poor shape) • Spare tire hold down plate Make offers on any of this stuff. Feel free to ask questions. I will be updating this list with more items shortly. Everything will ship out using USPS Flat Rate Boxes. |
dlee6204 |
May 25 2010, 11:08 AM
dlee6204 |
May 25 2010, 12:20 PM
amphiduck |
May 25 2010, 12:42 PM
Member Group: Members Posts: 94 Joined: 29-September 06 From: Tennessee Member No.: 6,947 |
Pm sent
mk114 |
May 25 2010, 01:02 PM
LOST in NO space (my garage) Group: Members Posts: 330 Joined: 29-March 05 From: Salt Lake Utah Member No.: 3,835 |
consider sold
driver side sun visor $5.00 |
dlee6204 |
May 25 2010, 01:12 PM
dlee6204 |
May 25 2010, 01:26 PM
dlee6204 |
May 25 2010, 01:40 PM
pilothyer |
May 25 2010, 01:59 PM
Member Group: Members Posts: 838 Joined: 21-May 08 From: N. Alabama Member No.: 9,080 Region Association: South East States |
Doug....I will take the following: 1.7L Oil Cooler Shroud w/ gasket (may fit other engines $5.00
Rubber Shock tower caps (both) $5.00 Drain Funnel $2.00 (need 2 if you have) Side marker light base $2.00 I may update list as you add more...Thanks...Jerry |
t collins |
May 25 2010, 03:59 PM
Advanced Member Group: Members Posts: 3,270 Joined: 21-March 06 From: Virginia Member No.: 5,754 Region Association: None |
I'll take broken side mirrow - 15.00
2 door strikers 2.00ea Horne cancel ring -2.00 Thanks, Tom PM sent |
dlee6204 |
May 25 2010, 04:13 PM
All PM's responded to.
Tom_T |
May 25 2010, 04:22 PM
dlee6204 |
May 25 2010, 04:39 PM
914Sixer |
May 25 2010, 07:54 PM
914 Guru Group: Members Posts: 8,876 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
I will take the ignition lock in the steering column if you want to sell it. Do you have a key?
dlee6204 |
May 25 2010, 08:08 PM
QUOTE I will take the ignition lock in the steering column if you want to sell it. Do you have a key? Sorry, that housing/switches have already been sold. |
Tom_T |
May 26 2010, 12:51 AM
SUNAB914 |
May 26 2010, 08:30 AM
Senior Member Group: Members Posts: 698 Joined: 29-December 08 From: Fredericksburg VA Member No.: 9,880 Region Association: South East States |
hey, does the fan have all blades? If so how much.
Thanks |
buhs914 |
May 26 2010, 06:57 PM
Not So Newbie Group: Members Posts: 331 Joined: 16-June 09 From: Buckeye, AZ Member No.: 10,478 Region Association: Southwest Region |
Hey do the tachs work? if so i'm interested in getting one of them to trade out internals with mine.
dlee6204 |
May 27 2010, 07:03 AM
PM's sent!
eyecolor |
May 30 2010, 07:57 PM
Eyecolor Group: Members Posts: 80 Joined: 15-August 08 From: Wilmington,DE Member No.: 9,425 Region Association: None |
Any chance you have a parking brake handle?
Lo-Fi Version | Time is now: 8th May 2024 - 05:59 PM |
