Mike Bellis |
Resident Electrician ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,347 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None ![]() ![]() ![]() |
I installed a Road Race oil pan on my V8. Now my shift rod is in the way. I need to decide on a J West or cable setup. Anyone have pics of the J west system from the firewall to the tranny?
JWest |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,663 Joined: 6-January 03 From: Fort Worth, TX Member No.: 97 Region Association: None ![]() ![]() |
The JWest linkage will give you less room than stock and travels along the same path as the original, so I don't think it will do you any good.
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,276 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
Anyone have pics of the J west system from the firewall to the tranny? http://www.914world.com/bbs2/index.php?showtopic=70331 You make your own shift rod using the one supplied by James. On my car, it's a straight line from the firewall coupler to the sideshift console coupler. You can make the rod any shape, as long as both ends are in the same plane ... (IMG:style_emoticons/default/shades.gif) Andy (IMG:http://www.914world.com/bbs2/uploads/post-179-1182814172.jpg) |
Mike Bellis |
The JWest linkage will give you less room than stock and travels along the same path as the original, so I don't think it will do you any good. The "bend" in the stock linkage hits the pan so no 4-5 gears. it hits the If I bend the rod to clear the pan, it hits the header so no 1-R gears. I have a window of 1.5 inches to get between. I'm thinking of U-joints, bearings and strait rod. If I can make the rod spin instead of swinging, it would shift fine. |
Mike Bellis |
Anyone have pics of the J west system from the firewall to the tranny? http://www.914world.com/bbs2/index.php?showtopic=70331 You make your own shift rod using the one supplied by James. On my car, it's a straight line from the firewall coupler to the sideshift console coupler. You can make the rod any shape, as long as both ends are in the same plane ... (IMG:style_emoticons/default/shades.gif) Andy There lies my other problem. The Renegade kit lowers the tranny 1 inch and moves it back 1.25 inches. Not on the same plain anymore. I'm going to need to offset the rod and use 3 or4 U-joints with a carrier bearing in the middle, maybe on the engine cradle. I no longer have a strait shot. The road race pan kicks out 3 inches on both sides of the pan. |
There lies my other problem. The Renegade kit lowers the tranny 1 inch and moves it back 1.25 inches. Not on the same plain anymore. (IMG:style_emoticons/default/confused24.gif) The JWest kit comes with U-joints on both ends. Moving the tranny around does not matter. Like i said above, as long as you get both ends in the same plane, you're good. The same plane on the movable end of the u-joints that is. If you can point each end of the u-joints at each other and there's nothing in-between that line, you got a straight shot, meaning both ends are in the same plane. Plane as in 3D, not 2D. (IMG:style_emoticons/default/shades.gif) Andy PS: See pics in my thread linked above ... |
Mike Bellis |
Here's my view from the rear.
Here's my view from the rear. No way that is going to work ... (IMG:style_emoticons/default/popcorn[1].gif) Either go to a cable shifter setup or customize your oil pan and cut off a few inches on that side to get more clearance ... (IMG:style_emoticons/default/smash.gif) Andy |
GS Guy |
Member ![]() ![]() Group: Members Posts: 243 Joined: 8-July 04 From: Columbia, MD Member No.: 2,325 Region Association: North East States ![]() |
My solution to a similar problem - I have 0 room to run a conventional linkage.
Dog-leg goes around obstructing framework and suspension. It's still in mock-up stage, but as long as I can get the parts connected securely, I see no reason why it won't work! (IMG:http://www.914world.com/bbs2/uploads_offsite/i140.photobucket.com-2325-1275005807.1.jpg) The far end of the dog-leg linkage is a mirror image of the trans end - in fact I used a long solid rod to align the two end bushings for welding. U-joints at both ends naturally. Biggest problem now is figuring a way to seal it all up while still allowing flexibility. Another "project" waiting its turn.... (IMG:style_emoticons/default/idea.gif) Jeff |
Mike Bellis |
I really don't want to cut the pan. It is baffled and has trap doors to send the oil to the pickup. Either option, cable or multiple u-joints isn't cheap. Cable would be easyest. I think I could fab something to work. The car don't move now so I have to do something...
Mike Bellis |
My solution to a similar problem - I have 0 room to run a conventional linkage. Dog-leg goes around obstructing framework and suspension. It's still in mock-up stage, but as long as I can get the parts connected securely, I see no reason why it won't work! Jeff Looks cool but I already have clearance issues and don't want the linkage below the cradle. I did consider this though and it would work for me. I'm just too afraid of breaking it on something and being stuck somewhere. |
McMark |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,180 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None ![]() |
A plane is by definition 2D. (IMG:style_emoticons/default/tongue.gif)
jimkelly |
Delaware USA ![]() ![]() ![]() ![]() Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region ![]() |
put a standard oil pan on it - most straight forward solution.
Mike Bellis |
But it is oriented in 3D space. Thus you need 3 vectors to define a plane in 3D space. The 3rd being the plane normal. Or use a triangle to define the plane. My post was trying to clarify that you don't have to have the rod mount on the transmission and the firewall at the same height as long as the two u-joint ends point at each other (being on the same plane) you're OK. That plane can be rotated any way in 3D space. All you need is a clear shot between the two. With his current setup, that's not the case. I'd say go cable shifter. I just saw a picture of a cable-shift setup on a 901 in another thread here ... (IMG:style_emoticons/default/shades.gif) Andy |
Eddie914 |
Unregistered ![]() |
How about moving the exhaust outboard?
Eddie |
Mike Bellis |
computers4kids |
Love these little cars! ![]() ![]() ![]() ![]() Group: Members Posts: 2,443 Joined: 11-June 05 From: Port Townsend, WA Member No.: 4,253 Region Association: None ![]() |
My motor motor was built for a circle track car and came in the crate with the same oil pan. I was able to reshape my shift rod to work, you can see the bend that goes around the renegade adapter. I had shorty headers. I eventually took the pan off and replaced with a stock baffled pan. My final shift rod used a 360 degree rotational end, combined with a Renshift made for a nice shifting car.
(IMG:http://www.914world.com/bbs2/uploads/post-4253-1212336263.jpg) (IMG:http://www.914world.com/bbs2/uploads/post-4253-1213055529.jpg) (IMG:http://www.914world.com/bbs2/uploads/post-4253-1241308086.jpg) |
Lo-Fi Version | Time is now: 30th July 2025 - 07:56 PM |
