Screw it I'm going in, An amateur restores a car (I hope) |
obscurity |
May 29 2010, 08:36 AM
Member Group: Members Posts: 411 Joined: 24-February 06 From: Atlanta ,GA Member No.: 5,628 Region Association: South East States |
Well we pick up our story already in progress but I hope that by forcing myself to post some pictures I will be motivated to keep going.
I bought the car may years ago and have yet to truely enjoy it. I have started to restore it several times and always get distracted but this weekend the baby (and his mother) is out of town and we have a three day weekend so lets see how far I can get. Here is where we are starting this morning. |
obscurity |
May 30 2010, 03:21 PM
If you come across spot welds (in appearance) that are gold in color when you grind them is that a braze? or was the last owner using some othe welding metal?
Can you weld to it or should I cut it out? |
scotty b |
May 30 2010, 07:11 PM
rust free you say ? Group: Members Posts: 16,375 Joined: 7-January 05 From: richmond, Va. Member No.: 3,419 Region Association: None |
If you come across spot welds (in appearance) that are gold in color when you grind them is that a braze? or was the last owner using some othe welding metal? Can you weld to it or should I cut it out? If it is truely a spot weld and is gold ( brazed ) it is not factory. Post a pic so we can see exactly what you are talking about. As steel gets hot it will turn goldish before it gets blue. Perhaps you just got the spot hot when grinding or drilling (IMG:style_emoticons/default/confused24.gif) |
rick 918-S |
May 30 2010, 07:27 PM
Hey nice rack! -Celette Group: Members Posts: 20,462 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
If you come across spot welds (in appearance) that are gold in color when you grind them is that a braze? or was the last owner using some othe welding metal? Can you weld to it or should I cut it out? If it is truely a spot weld and is gold ( brazed ) it is not factory. Post a pic so we can see exactly what you are talking about. As steel gets hot it will turn goldish before it gets blue. Perhaps you just got the spot hot when grinding or drilling (IMG:style_emoticons/default/confused24.gif) If it's brass you can't weld to it. Remove it. Photos are always good. (IMG:style_emoticons/default/popcorn[1].gif) |
Lo-Fi Version | Time is now: 18th May 2024 - 12:43 PM |
