Screw it I'm going in, An amateur restores a car (I hope) |
obscurity |
May 29 2010, 08:36 AM
Member Group: Members Posts: 411 Joined: 24-February 06 From: Atlanta ,GA Member No.: 5,628 Region Association: South East States |
Well we pick up our story already in progress but I hope that by forcing myself to post some pictures I will be motivated to keep going.
I bought the car may years ago and have yet to truely enjoy it. I have started to restore it several times and always get distracted but this weekend the baby (and his mother) is out of town and we have a three day weekend so lets see how far I can get. Here is where we are starting this morning. |
charliew |
Jul 5 2010, 05:15 PM
Advanced Member Group: Members Posts: 2,363 Joined: 31-July 07 From: Crawford, TX. Member No.: 7,958 |
My thoughts are you have blown off the best info provided so far. If you don't brace the tub you will not be happy with the outcome. If someone told you it doesn't need bracing the've never done it with this much removed at one time. THERE IS NO WAY that tub can stay straight while it is being heated and cooled. Every time a bead is put in it will shrink some as it cools, the idea is to limit it as much as possible. If you think it is cut up now wait till you try to straighten it out. But it will be a great story so try your best and lets see how you end up. The door gap and the twist, think about it. A support under the middle of the long and the center tunnel will also help. How long has it been suspended between the outer supports? Try putting a 8ft 2x4 on two supports at the ends and let it stay there for a month and see what happens. Metal is only stronger but it still does the same thing only less.
I forgot, the time to build the brace was before you cut all the pieces out. Somehow you are going to need to do some real close measuring on the top gap and the door gap top and bottom, and the side to side diagonal before you start to make sure it doesn't change as you proceed. You can put a straight edge on the outside of the doors to see if either side is out from the fender or quarter on the outside. Good luck and I hope it works out but you are in a pretty interesting spot at this point. You do seem to have some metal working skills though so maybe this will prove to everyone that has done it, it really doesn't need bracing if you are good enough. |
Lo-Fi Version | Time is now: 19th May 2024 - 06:28 PM |
