> Carb trouble!
JRust
post Apr 8 2003, 11:58 AM
Hey guys I'm having a little trouble with my weber44's. My passenger side carb seems to have the float or something sticking. After running for a while it stops getting fuel. My fuel lines are all new to both & I checked them for plugs. I'm definately not the best mechanic. I'm wondering if there is a good rebuild kit for them 44's. I can follow directions pretty well & think I could probably handle the carbs. Or at least do my usual of doing it myself & then paying my wrench to fix my work! Any thoughts & experiences appreciated! (IMG:style_emoticons/default/biggrin.gif)
boxstr
post Apr 8 2003, 01:17 PM
Jamie You have said it all. Take it to your wrench.
CCLinLOO
JRust
post Apr 8 2003, 05:32 PM
Really I expected a much more sarcastic remark from you Craig. Something like thats what you get for switching to carbs from the FI. Then something like a you dumbass remark! (IMG:style_emoticons/default/biggrin.gif)
I figure on taking it to my wrench next week. It was nice to cruise around in it today though! Top down & happy me! We need to have a get together soon. Any autox coming at PIR soon?
Brad Roberts
post Apr 8 2003, 05:39 PM
914 Freak!
Tap on the carb with the wooden end of a hammer. The float may be sticking. You can easily pull the top off of the carb in question. Remove the air cleaner/remove the velocity stacks/then start unscrewing all the screws for the carb top itself. The carb top lifts out of the body of the carb and the floats stay with it (unless I'm mixing it up with Dell carbs) << I know the float stays with those. You can then "work" the float by hand and even have somebody turn the pump on for you while you hold the floats in the closed position. Slowly open them and watch for fuel. Do this over a container of some sort to catch the fuel.
You dont need a rebuild kit to figure this out.
B
my15window
post Apr 8 2003, 05:52 PM
get yhe weber book it breaks down all the symptoms and tells you what is clogged or not adjusted. normally a clogged jet though, best 13.00$ I ever spent
Brad Roberts
post Apr 8 2003, 05:53 PM
914 Freak!
You have a 15 window Bus ??
B
Porsche Rescue
post Apr 8 2003, 06:05 PM
Saving and Enjoying Old Porsches
Jamie, I am with Brad on this. Your problem does not require a rebuild. Just need to figure out why it is not delivering/getting fuel on that side. I have a couple of Weber manuals which I will loan you if you can stop in to get them.
my15window
post Apr 8 2003, 06:20 PM
A 1961 15 window, A 57 oval window, and a 73 914 with a 2.5 being built demillo the guy that makes all of fat's parts doing alot of the machine work ,78 crank and balancing it alll too oh yea, a 1938 pre war chris craft I'm working on
Brad Roberts
post Apr 8 2003, 06:44 PM
914 Freak!
YOU Rock. Nice collection. I always loved the Safari window buses. I think my dad owned a 61 VW pickup way back.
The Chris Craft is all wood correct ?
Who is this guy Demillo ? Is he the guy who makes the full circle "Demillo" cranks ?? I think we have his name spelled incorrectly.
B
my15window
post Apr 9 2003, 05:31 PM
your right, it's demello, like I said he does all the cranks a and rods for fat, crank rods 14lbs flywheel balnce fan, then balance it all together plusopae case to 103s for 700 not bad ..
Brad Roberts
post Apr 9 2003, 05:33 PM
914 Freak!
That is a pretty good price. Show us pics of the pieces when you get them back.
It would also be nice to get some contact info for him.
B
my15window
post Apr 9 2003, 05:48 PM
demellocranks.com a really good guy too..
- Lo-Fi Version Time is now: 15th April 2024 - 10:48 PM
