Vacuum Lines.... Again, Yes I am an idiot, thanks |
tdgray |
Apr 6 2004, 09:06 AM
Thank God Nemo is not here to see this Group: Members Posts: 9,705 Joined: 5-August 03 From: Akron, OH Member No.: 984 Region Association: None |
Someone mentioned awhile ago that the Bird had a tech article or something listing the approx. lengths of the various vaccum lines. Damned if I can find it. Wanted to order some new vaccum and fuel lines but I don't know how much (IMG:style_emoticons/default/huh.gif)
BTW are we all agreed that it is OK to replace the plastic fuel lines with Stainless Steel 5/16 (oops edited) lines or am having flashbacks again? (IMG:style_emoticons/default/wacko.gif) |
ArtechnikA |
Apr 6 2004, 09:11 AM
QUOTE(tdgray @ Apr 6 2004, 07:06 AM) BTW are we all agreed that it is OK to replace the plastic fuel lines with Stainless Steel 5/8 lines or am having flashbacks again? i'll assume you meant 5/16" or 3/8" ... several people have done it. if you're using stainless you'll have a harder time finding fittings and getting them welded on; if you're using hose clamps i HIGHLY recommend getting the prober tubing beading tool. most people have used 5/16" mild steel truck brake line; easy to attach proper AN fittings to that ... |
mike_the_man |
Apr 6 2004, 09:18 AM
I like stuff! Group: Members Posts: 1,338 Joined: 11-June 03 From: Regina, Saskatchewan, Canada Member No.: 809 |
tdgray |
Apr 6 2004, 09:57 AM
Thanks guys (IMG:style_emoticons/default/mueba.gif)
I think I will investigate the mild steel v the stainless issue further. |
Lo-Fi Version | Time is now: 17th May 2024 - 08:19 AM |
