Mueller |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,155 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None ![]() ![]() |
as copied from the GGR rules book:
QUOTE Tires: i. Street tires: Any street tire/wheel combination may be used. Tires must be DOT approved. ii. Race Tires: Race tires may be used, but may not be mounted on wheels wider than seven (7) inches or one inch wider than stock, whichever is greater. This leaves open the possibility of cars being competitive on very large street tires. given the choice, what would be better and more cost effective?? wide street tire/wheel or 7" wide rim with race tire are there DOT tires "close" to being a race tire??? |
brant |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,011 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains ![]() ![]() ![]() |
let others chime in here.. but race tires defines as slicks, and slicks are stickier....
dot tires includes hoosiers and the like.. yes they are fast, but they are still not slicks... which would be better?... depends upon how wide you would go with the hoosier I suppose.... alignment settings between a slick and dot, would be very different too.... b |
GaroldShaffer |
You bought another 914? ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 7,628 Joined: 27-June 03 From: Portage, IN Member No.: 865 Region Association: None ![]() ![]() ![]() |
Are you running in SCCA if so what class? going to slicks will bump you up from street to modified.
- Garold |
Mueller |
sorry, PCA only right now......for some of the local open track events, the car is not really classed as much as the driver experiance and I'll be in the slower run groups for a while (IMG:style_emoticons/default/smile.gif)
Group: Posts: 0 Joined: -- Member No.: 0 ![]() |
if it's DOT R compounds, then it's a "street tire". basically, RA1's, and Hoosier R3S03's or R4's are legal because they are DOT approved.
"Race tires" are way different. and extremely sticky! They do not have any "DOT" ratings on them |
Mueller |
i was not sure if all they do is add a water channel to make a "race" tire into a DOT tire...I'm guessing not now (IMG:style_emoticons/default/smile.gif)
huge price differential between the two??? |
Oops, forgot to mention. I'd get some Hoosier R3S03's. Haven't heard much on the new S04's yet.
john rogers |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,525 Joined: 4-March 03 From: Chula Vista CA Member No.: 391 ![]() |
I'd say run Goodyear cantilever slicks. They were made for 7 inch rims but are a little over 9 inches wide at the contact patch. They have very very stiff side walls so the flex you get with the Victoracers and other "DOT" approved race tires is eliminated. This is very easily seen when I follow a a 914 or 911 with the DOT tires and I can actually see the car dancing from the tire movement on a fast banked track such as CA Speedway. The down side is they are a little more expensive and take a lap to get really sticky as the Victoracers are good when the green flag drops.
Demick |
Ernie made me do it! ![]() ![]() ![]() ![]() Group: Benefactors Posts: 2,312 Joined: 6-February 03 From: Pleasanton, CA Member No.: 257 ![]() ![]() |
Mike
There's really 3 levels: Street tires DOT-R tires Race tires Street tires are usually referred to as tires which have a wear rating of 120 or more. You will not be competetive with any of these tires. The DOT-R tires are in between street and race. They are DOT approved, so they are officially street legal, but they are not tires you would want to drive on the street. Wear rating is usually 50. They will not be as fast as race tires, but are competetive and are considered the best bang for the buck. Lots of people run these. Race tires are just that. Very sticky and fast, but wear quickly and are expensive. Don't buy these unless you are a good enough driver to need that extra edge to come out on top. Demick |
Mueller |
thanks Demick !!!!
brant |
As usual others have more clearly expressed than I am able..
but mike I just wanted to comment regarding your mention of the rain channel.. dot certification involves quite a bit more than a rain channel... There is a federal testing process with load/time/heat etc.... Certification is a pain in the butt, and I don't imagine its cheap either... Sorta like crash certification for cars... a lot of low volume manufactors don't want to/can't afford to go through it... The full race slicks haven't been through it... doesn't mean they will blow up or kill you ... they may or may not pass the test.. but the differences are more than a rain groove.. There are a few tire that fall into this inbetween.. for example the hoosier rain tire. Its compound is more similar to a dot tire than a slick.. its composition and side wall is also more similar to a dot than a slick.. yet hoosier didn't bother to put it through certification probably for cost reasons.. I've heard that it was actually faster than the 03 hoosiers, but didn't qualify as a dot for pca stuff, so it gets classified as a race tire even though it is truly not built like a slick... true slicks are another world. very different in every way.. most will heat cycle out before they wear out. Go with the DOT... use something cheapish to learn on. My experience with 2nd tear level tires has shown that the victoracer works better with a 2000lb car where as the yoko is superior with a 3000lb car..... just buy one of these consistent and longer lifed tires, and then do the driver training route. b |
seanery |
waiting to rebuild whitey! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 15,857 Joined: 7-January 03 From: Indy Member No.: 100 Region Association: None ![]() |
(IMG:style_emoticons/default/agree.gif) with Demick
The first time I used a DOT-R tire (BFG R1) was at Laguna. I drove the car up there on real street tires then switched over to the DOT-Rs. They were plenty sticky for DEs. I'm sure the faster you'll go you'll want slicks more, but until I reach that point DOT-Rs are my choice. |
Mueller |
i drove my C2 on the street with Comp R1's for a few thousand miles when I first got it, awesome grip..then I put on the Kuhmo 712's since the car is mostly just a "driver" and I knew the rain was coming soon at the time....what an f'n disapointment with the Kuhmos (and not just due to the blow out) (IMG:style_emoticons/default/sad.gif)
URY914 |
I built the lightest 914 in the history of mankind. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 127,402 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None ![]() |
Mike,
I have offen debated the race slick vs. autox R with others in the past. I even posted the question a month or so ago. If you are speaking of ONLY autox use, I think a shaved, R rated autox tire will be quicker. Here is why, 1. Slicks in our size are not made in the sofest of compounds. Check Goodyear's race tire website. They have a table that has the compounds listed. 2. As stated earlier, slicks take time to come up to temp. On a autox you don't have this time to wait. 3. An R rated autox tire is designed to heat up quick. Now this all changes when you have wheels and fenders that allow you to mount the softest compound. But of course, you just moved up to a differnt class. The debate continues.... (IMG:style_emoticons/default/confused24.gif) Paul |
J P Stein |
Irrelevant old fart ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,797 Joined: 30-December 02 From: Vancouver, WA Member No.: 45 Region Association: None ![]() |
The differences between "race tires" (slicks) and AX specific tires has become increasingly blurred.
I agree with Paul except: AX specefic tires don't need to heat up to get their grip. They are sticky righ out of the box.....or so I am told. I won't have personal experience with this for a couple weeks, but I trust the folks telling me this. The new Hoosier are like a "qualifying" slick. Dunno if they would last more that 2-3 laps on a race course....less for the Kumho's if recent reports are true (IMG:style_emoticons/default/laugh.gif) In any case, I would recommend Kumho Victoracers..205 X 15 or 16 as a good place to start. You're gonna get your head handed to ya regardless....don't take it personal, it happens to everyone.(IMG:style_emoticons/default/laugh.gif) |
Mueller |
thanks, Paul, JP and everyone else...it seems that the "regular" auto-x tires in the 205-ish size would be best for my car, especially since I am just starting out....
ss6 |
fun city... ![]() ![]() Group: Members Posts: 261 Joined: 2-February 03 From: Western Connecticut Member No.: 221 ![]() |
Check out Michelin's Pilot Sport Cup. Very popular at our local DE's. Very close to the Hoosiers in grip, but they don't poop out after only a dozen heat cycles. Some guys have gotten an entire season out of a set (though we don't get as many track days out here as you CA guys do). Just don't start flogging them until you've warmed them up; probably not a good AX choice for that reason. Street legal enough to drive to the track.
Demick |
Truthfully Mike, I'd encourage you to simply run street tires for the first year or so. You won't be competetive anyway for 2 reasons:
1. It takes awhile to get the car handling sorted out and to your liking 2. You need to learn how to drive (no offense intended). Being a 'good driver' on the street doesn't mean crap when it comes to the autox course. Being competetive at the autox simply takes some experience and time behind the wheel. I think that you learn much faster how the car handles at its limits with street tires. This is helpful both in sorting out the car's handling as well as your learning how the car handles. I ran for 3 seasons on street tires before making the transition to DOT-R tires. Yes, you will be faster with DOT-R tires, but since you aren't likely to be competetive either way (at first), you might as well save the $700 and learn on street tires. Besides, it's always a convienant excuse as to why you aren't competetive! (IMG:style_emoticons/default/smile.gif) Demick |
Mueller |
Hey Demick...
points well taken and not offended at all (IMG:style_emoticons/default/smile.gif) it might be safer with the street tires as well, since the adhesion limit will be lower so I am "forced" to slow down until I know what to do at the higher speeds....... |
J P Stein |
Demick makes a good point, but with the following caveat. Some street tires have lousy recovery characteristics. I have some Yoko Intermediates that are pretty good. I had a set of Dunlops that were terrible. The Victoracers are very catchable.
Since you have a turbo, this is even more important. In AX, boost is not good unless the car is pointed straight ahead when it comes on. Otherwise....lurid slides look cool but aren't the quick way around.....assuming you can catch the slide. I ran 4-6 AXs on street tires.....the Dunlops....before saying "the hell with this" and got some Vracers.....don't feel I missed much. |
Lo-Fi Version | Time is now: 11th July 2025 - 04:08 AM |
