Cooling system flaps, how are they supposed to be oriented? |
brandomc |
Jun 16 2010, 02:06 PM
Member Group: Members Posts: 113 Joined: 14-May 09 From: los angeles california Member No.: 10,363 Region Association: Southern California |
I just got my 2056 back from my engine builder, and now im trying to install all the sheet metal. The engine builder suggested that i wire open my cooling system so that it doesnt ever mess up and overheat my engine. My question is how should the flaps be oriented if i wire them open. Why do i even need these flaps if im not using the thermostat system? IF anyone has any pics of how they oriented their flaps, that would help alot. Thanks!! Hopefully back on the road soon!!
iankarr |
Jun 13 2019, 07:33 PM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,480 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
Holy thread resurrection!
Yes, the thermostat can be put in with the engine in the car. Not a big deal. but make sure the bolt which holds the thermostat pulley is installed regardless. It's a through passage and you'll have a lot of oil everywhere if it's not installed! |
Jun 13 2019, 07:54 PM
Resident German Group: Admin Posts: 41,664 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
While i agree with the above, before you put a thermostat back on there make *sure* you still have the cooling flaps and they are operational.
Otherwise the thermostat won't do squat ... (IMG:style_emoticons/default/sunglasses.gif) |
mtc911 |
Jun 13 2019, 08:46 PM
Member Group: Members Posts: 65 Joined: 18-March 18 From: Atlanta Member No.: 21,978 Region Association: South East States |
While i agree with the above, before you put a thermostat back on there make *sure* you still have the cooling flaps and they are operational. Otherwise the thermostat won't do squat ... (IMG:style_emoticons/default/sunglasses.gif) Is that doable with engine in? Removing all that tin? My assumption is it might all be gone if the therm is gone. Might explain the high CH Temps |
rhodyguy |
Jun 14 2019, 01:24 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,084 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Then you need the wheel and bracket too. No néed to remove the top tin and the rest of the hardware. Feed the new wire down or pull it up with a piece of scrap wire. Leave some wire length at the rod connection. If it's too short and you have to release the top, you'll play hell trying to hook it back up. Frustrating lesson. Had to buy a new cable.
Lo-Fi Version | Time is now: 29th May 2024 - 02:46 PM |
