Engine Progress, North of the border almost done |
tracks914 |
Apr 6 2004, 06:40 PM
Canadian Member Group: Benefactors Posts: 2,083 Joined: 15-January 03 From: Timmins, Ontario, Canada Member No.: 153 Region Association: None |
Before
tracks914 |
And After
tracks914 |
Apr 6 2004, 06:41 PM
And Under
F4i |
Apr 6 2004, 06:42 PM
914 DOG! Group: Benefactors Posts: 482 Joined: 22-December 03 From: AB Canada Member No.: 1,460 |
I guess we Canadians can build some nice motors. Looks really nice!
tracks914 |
Apr 6 2004, 06:46 PM
So far...
Polished crank New crank bearings New rod bearings New rings New valves New valve guides Heads blasted and polished (just because I can) Old cam still in spec. Electronic Ignition in rebuilt distributor All tin glass beaded and painted (no Powder up here (IMG:style_emoticons/default/sad.gif) ) All stock Wow, never thought it would take so long to assemble the auxillaries. I started with the block and heads assembled and most of the engine tin last Saturday AM. 10 1/2 hours later, I had the intakes, hoses, FI fuel lines, engine tin, alternator, and injectors installed. Definately not a water cooled engine. Tomorrow I will work on the engine electrical. Its amazing how things look different cleaned, painted and almost 5 months from disassembly. But thanks to Haynes and a few pictures off this site I think I will have it all back and running soon. The only thing that concerns me was the hack job hot wiring that was on the engine when I took it apart. Who knows why they did it but I might soon find out. (IMG:style_emoticons/default/unsure.gif) |
Mark Henry |
Apr 7 2004, 07:10 AM
Looks good Doug! (IMG:style_emoticons/default/smilie_pokal.gif)
Bleyseng |
Apr 7 2004, 08:04 AM
Looks great! (IMG:style_emoticons/default/smilie_pokal.gif)
Did you paint the pushrod tubes? hmm, normally don't see that. Hope you used new injector seals and bits too. Geoff |
Mark Henry |
Apr 7 2004, 09:08 AM
I know for sure he used new injector seals. (IMG:style_emoticons/default/wink.gif)
Did you use new FI hose? you should. |
tracks914 |
Apr 7 2004, 08:14 PM
QUOTE(Mark Henry @ Apr 7 2004, 07:08 AM) I know for sure he used new injector seals. (IMG:style_emoticons/default/wink.gif) Did you use new FI hose? you should. The short pieces going to the injectors are new fuel line. The longer ones are still the fabric covered braided lines. I trimmed the ends off of them to get to good rubber and get a good seal. I love the look of the original hoses but couldn't get any of that material up here. The same goes for most of the vacuum lines. If I could get another long red one for the right side and one for the air cleaner it would dress up the engine right nice. I'm a stickler for that "original" thing. I plan on pressure testing the fuel lines before I put it in the car. I figure about 35 psi would do it as long as it won't damage any of the pressure sensors. What do you think? Tx Doug |
Bleyseng |
Apr 7 2004, 08:24 PM
Black fabric high pressure fuel hose is available and much safer than any old fuel line. The damn stuff develops small cracks which sprays gas on the hot engine, not good.
Please replace by ordering from Brad at HighPreformanceHouse or PP. Maybe HPH has some of that OEM red hose laying around too. Better safe than sorry when it comes to this....don't want another 914 to burn to the ground. (IMG:style_emoticons/default/sad.gif) 35lbs is plenty of test fuel pressure. Geoff |
lmcchesney |
Apr 7 2004, 08:58 PM
Member Group: Members Posts: 488 Joined: 24-November 03 From: Ocala, Fl. Member No.: 1,381 Region Association: None |
How about those old plastic center tunnel lines?
Good time to replace with the engine out. L. McChesney |
Mark Henry |
Apr 7 2004, 09:13 PM
Yes, that hose can be bad even though it "looks" OK.
Doug I'm ordering in a couple of days, PM me if you want some. I can't get the red smog hose, only black. |
tracks914 |
Apr 9 2004, 07:01 PM
OK you all win. I took the old fuel line off and replaced it all with new FI hose. I will look into that braided stuff later. I want to get the car running first.
As for the tubes, yes I painted them. They looked pretty ratty so I figured they could only look better in black. Tx Doug |
Lo-Fi Version | Time is now: 22nd May 2024 - 05:30 PM |
