External Oil Cooler, let me see some pictures |
tradisrad |
Jun 22 2010, 11:03 AM
Senior Member Group: Members Posts: 985 Joined: 11-September 06 From: San Mateo, CA Member No.: 6,815 Region Association: Northern California |
I am going to install my 25 row Earls oil cooler over the 4th of july and I am looking for some more ideas, tip and tricks.
I plan on using a wafer adapter to keep my filter in the stock location. I will also install a thermostat and a fan. I will most likely mount it under the rear trunk. I'd like to see some pictures of what others have done. Experinces on the wafer adapter vs relocating the oil filter and what thermostats are being used. I've seen the Pelican Article. thanks -Rob |
tradisrad |
Jun 23 2010, 07:36 AM
zx-niner, wow that is clean. Talk to me a bit about your full flow system. I was toying with this idea, but I don't know much about it.
Where is you filter mounted? Looks like it is attached to the head; what remote mount did you use? and did you use the CB performance oil thermostat? You guys have a lot of nice looking oil cooling systems. Thanks for sharing I am getting a good picture of what I need to do. |
Lo-Fi Version | Time is now: 17th May 2024 - 02:51 AM |
