External Oil Cooler, let me see some pictures |
tradisrad |
Jun 22 2010, 11:03 AM
Senior Member Group: Members Posts: 985 Joined: 11-September 06 From: San Mateo, CA Member No.: 6,815 Region Association: Northern California |
I am going to install my 25 row Earls oil cooler over the 4th of july and I am looking for some more ideas, tip and tricks.
I plan on using a wafer adapter to keep my filter in the stock location. I will also install a thermostat and a fan. I will most likely mount it under the rear trunk. I'd like to see some pictures of what others have done. Experinces on the wafer adapter vs relocating the oil filter and what thermostats are being used. I've seen the Pelican Article. thanks -Rob |
tradisrad |
Jul 11 2010, 10:21 AM
Oil cooler is installed. I mounted it under the rear trunk, ran the cooler lines through the engine compartment, added a thermostaticly controlled fan.
I am able to keep my oil temps down around 180 to 190 with the fan running. I pulled the fan fuse and noticed the temps climb into the 210 range. I am pleased with the outcome. Oil cooler: Lines passing into the engine compartment: Mocal adapter: My next part of the project will be to add a small LED in the oil temp gauge to indicate when the fan is on. But it may be a while.... |
Lo-Fi Version | Time is now: 17th May 2024 - 05:21 AM |
