External Oil Cooler, let me see some pictures |
tradisrad |
Jun 22 2010, 11:03 AM
Senior Member Group: Members Posts: 985 Joined: 11-September 06 From: San Mateo, CA Member No.: 6,815 Region Association: Northern California |
I am going to install my 25 row Earls oil cooler over the 4th of july and I am looking for some more ideas, tip and tricks.
I plan on using a wafer adapter to keep my filter in the stock location. I will also install a thermostat and a fan. I will most likely mount it under the rear trunk. I'd like to see some pictures of what others have done. Experinces on the wafer adapter vs relocating the oil filter and what thermostats are being used. I've seen the Pelican Article. thanks -Rob |
brp986s |
Jul 12 2010, 02:32 PM
Member Group: Members Posts: 434 Joined: 27-September 07 From: los angeles Member No.: 8,167 |
The fan is exiting up here. The fan is 20% less efficient in push-mode according to the manufacturer. Until I learned that I considered ducting down and using that air as input to the heat exchangers since the engine came with block-offs. I balked at the cost of custom HE's and just run MSDS headers. Don't need heat in So Cal anyhow.
Lo-Fi Version | Time is now: 19th May 2024 - 03:56 PM |
