External Oil Cooler, let me see some pictures |
tradisrad |
Jun 22 2010, 11:03 AM
Senior Member Group: Members Posts: 985 Joined: 11-September 06 From: San Mateo, CA Member No.: 6,815 Region Association: Northern California |
I am going to install my 25 row Earls oil cooler over the 4th of july and I am looking for some more ideas, tip and tricks.
I plan on using a wafer adapter to keep my filter in the stock location. I will also install a thermostat and a fan. I will most likely mount it under the rear trunk. I'd like to see some pictures of what others have done. Experinces on the wafer adapter vs relocating the oil filter and what thermostats are being used. I've seen the Pelican Article. thanks -Rob |
tradisrad |
Jul 25 2010, 05:09 PM
I added an LED to my oil temp gauge to indicate when the oil cooler fan is on. I drilled the led hole a bit low and the light clips the top of the "220", but I don't think it looks too bad (for having limited tools and doing it by hand).
The needle is capable of clearing the LED if it ever gets that hot and it is hard to see when it is off. I also added a variable resistor the the back of the gauge so I can controll the brightness of the LED. Now my oil cooler project is done. since the oil temps are not getting too hot my oil pressure is staying high. This next picture is on the freeway at 3k rpm. I have been told that the pressure is good and I should be happy, but I guess I need something to worry about because I think it's a bit too high. |
Lo-Fi Version | Time is now: 18th May 2024 - 07:38 PM |
